Wraith center axle Diff cover for 6x6 has anyone with the capability thought about making a AR60 Diff cover that would allow you to add a second pinion making it a center axle for a 6x6? |
Re: Wraith center axle Diff cover for 6x6 Gcm metalhead axles are the only "wraith" axles that I've seen with the potential. I've never seen it done before, but I'm sure Clay at Carter Fab could make it happen"thumbsup" |
Re: Wraith center axle Diff cover for 6x6 I think all that needs to be done is a diff cover (aluminum of course) with bearing pockets and ready to bolt on would be fairly simple to do. Stock housing would work to keep the cost down. "thumbsup" |
Re: Wraith center axle Diff cover for 6x6 Do you have a wraith axle? there are 4 tiny screws that hold the diff cover on. Definitely not enough material structurally to mount a pinion on the cover side unless it bolted to the bearing caps |
Re: Wraith center axle Diff cover for 6x6 Quote:
I've seen a couple drawings of people planning to do it but never seen anyone follow it through. The 6x6 market just isn't very big. |
Re: Wraith center axle Diff cover for 6x6 The gcm axles could easily be converted |
It's a good idea, also seen a couple decent looking protos. One in particular looks very decent. Indeed a small market but hope to see one make the light of day. |
I went through my materials today, I'll post up whatever I make here for you guys to see. "thumbsup""thumbsup" |
Re: Wraith center axle Diff cover for 6x6 Not really the way you are talking about this guy just used a second transfer mounted between the rear axles.https://www.google.com/url?sa=t&rct=...64542518,d.cWc |
As far as making something capable for the wraith, it would need to mount to the bearing cap screws (M3 vs tiny M2) and machined from aluminum. For something machined, you would need enough interest for it to be worth doing (one offs are expensive). 6X6's are already rare, but one the size of AR60 axles is even more rare. I think what might help is that if enough people see a viable prototype, that might spark some interest in making a big 6X6, causing some demand for the conversion piece, allowing a manufacturer to get on board with actually making it. |
