04-02-2014, 01:10 PM | #1 |
Newbie Join Date: Mar 2010 Location: Malta
| 3d Printing Chassis
Hi, I have scaled up an axial wraith chassis to be compatible with an HSP. The idea was that I would build it by brazing. Just out of curiosity I uploaded (not yet complete) 3d design of the chassis onto i.materialise.com. They can also print in stainless steel. Does anyone have any experience with 3d Printing chassis. Is the end result strong enough to work as a crawler chassis? Any opinions? [/url] Thanks, Sean |
04-02-2014, 01:21 PM | #2 |
RCC Addict Join Date: Jan 2010 Location: Vermont
| Re: 3d Printing Chassis
I am currently in the process of printing a tuber too. I am in a 3D Printing class my gallery is offering (it's free, so I'm in it). My application is strictly WE Rock unlimited class, so pretty slow and scale. The metals is definitely an intriguing material for these printers... Game Changer... |
04-02-2014, 01:30 PM | #3 |
There was a guy on here and on scale4x4 that prints a Wild Willys chassis. Haven't heard much lately on that project. |
04-02-2014, 01:39 PM | #4 |
Quarry Creeper Join Date: Jan 2013 Location: Benicia/Vallejo
That's really cool, I had no idea that was an option let us know how it turns out
04-02-2014, 01:54 PM | #5 |
I'd be curious to the process to see if it uses a fill material for support while the main part is being printed.
04-02-2014, 01:59 PM | #6 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| Re: 3d Printing Chassis I would be curious to know it was durable enough to handle full on action. It certainly should be good enough to check clearances and other prototyping. Last edited by Fishmaxx; 04-02-2014 at 02:04 PM. |
04-02-2014, 02:06 PM | #7 |
Not an application I would consider 3D printing. I have tons of 3D models of chassis and have the 3D printer at home, but the amount of support material, the number of direction changes in the tubes and such would cause odd printing requirements. A rail chassis would be different but still not where 3D printing is ideal. It's strong but not that strong. I would not use it in suspension applications at all.
04-02-2014, 02:32 PM | #8 | |
| Re: 3d Printing Chassis Quote:
04-02-2014, 02:45 PM | #9 |
Its been scaled to fit an HSP 1:8 crawler. According to their website: "Models made in stainless steel are printed in stainless steel powder that is infused with bronze. Stainless steel is the cheapest form of metal printing, very strong and suitable for very large objects." I've seen a few videos of designs made by them in stainless steel. Seem to be quite solid. Not yet sure but its not expensive so I might give a try and see how it goes. There are also some guidelines (tips and tricks) to get a better product. Minimum thickness etc.. |
04-02-2014, 09:08 PM | #10 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Shapeways is also another option. They offer several types of materials also.
04-02-2014, 10:22 PM | #11 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
Wouldn't the 'sintered' type of construction that 3D printing gives result in embrittlement?
04-02-2014, 11:23 PM | #12 |
Be the pioneer and just try it. If it fails, you know for a fact it isn't strong enough.
04-03-2014, 07:22 AM | #13 |
I work for a 3d printing company and I'd probably print it out of SLS nylon or SLS titanium because those print without supports for the most part and you don't have any weakness between layers. The metal printers are limited to the size that they will print though. You'd have to break it down into a few sections. Even the $1,000,000 printers only print a volume about 6" x 6" x 6". There are a few out there that will print up to 12" x 12" x 12", but they are generally reserved for aerospace and government type jobs. I've actually printed stuff like that out of nylon before for other projects and it holds up well. I don't know about the other products out there, but using my stuff I'd do the following: 1. Use Geomagic Design to double check the printability. You can pick the different printers and materials and it will tell you where it's too thin and needs beefing up. 2. Submit job to QuickParts and talk to one of the project managers. It would be assigned to them and they can explain exactly how it would be made. Heck, if you're going to beat it up too badly, they can even have it welded or braised out of tubing or solid rod. QuickParts will have anything you want manufactured in any method you need. 3. Wait and the item is shipped to you. I'm not trying to sound like a commercial, but there are definitely technologies that are doable for that type of part. FDM isn't applicable like Harley said because you need a ton of supports. Another reason why FDM isn't going to be ideal is the stratification (layers). When you have those long tubes traversing more than one layer, you have a week point (especially if a tube is printed in Z). SLS and SLM don't need supports for the most part and don't have defined layers. SLS and SLM printers are too expensive for the home still and this is why you need to have a service bureau print them for you. I have them at work, so I get to cheat and work in jobs when it's applicable. Lastly, it's probably about $1,000 to print that part when you use a service. The amount of material isn't that much, but you're paying for post processing and knowing how to do it. |
04-03-2014, 11:08 AM | #14 |
Pebble Pounder Join Date: Mar 2011 Location: coastal georgia
@ ik632 Do you work for 3D or does your company have their stuff? @ seansammut If you don't mind, can you let us know approx how much the want for the job? |
04-03-2014, 11:30 AM | #15 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
Wait! The ability to print with metals? Where the hell have I been? I need to start paying attention to the 3d printing field. Dang new stuff happens fast. Probably been printing metal for years.
04-03-2014, 01:00 PM | #16 |
| Re: 3d Printing Chassis You can print titanium as well as other metals. There is an outfit 3d printing glass. Heck, the bio firms are printing cells to start making skin and simple organs.
04-03-2014, 02:57 PM | #17 |
Sorry guys :( I made an awful mistake. It seems that when I uploaded the file its taking the measurements divided by 10 so instead of being 398mm it showing 39mm which is obviously not the correct dimension. Adjusting the dimensions set the price over 200EUR :( !!! arghhh back to brazing! |
04-03-2014, 04:35 PM | #18 | |
RCC Addict Join Date: Jul 2009 Location: Near Boston
: \ I wish it was cheaper but we are not quite there yet. That being said I have had really good success printing chassis skids with the ABS stuff on an FDM printer. A little teflon tape on the bottom and you are good to go. | |
04-08-2014, 09:55 AM | #19 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
200 euros isnt a bad price for that kind of chassis imo.
04-23-2014, 10:02 PM | #20 |
Newbie Join Date: Mar 2014 Location: paradise
Wow I did not know you could 3d print with metal powder that's awesome my buddy is looking at getting one going to have to learn to use it any good places too read or programs to download Sent from my HTC6600LVW using Tapatalk |
3d Printing Chassis - Similar Threads | ||||
3D printing section | Tontos_Touch | Comments, Suggestions, and Help | 3 | 03-06-2014 12:10 PM |
Who does 3D printing? *Call out* | Lentsnh2012 | General Scale Talk | 2 | 11-29-2013 05:27 PM |
3D printing | Micropuller | Chit Chat | 25 | 11-01-2013 11:47 AM |
Looking for 3-d printing help | scale4x4 | Chit Chat | 2 | 05-02-2013 04:14 PM |
3d Printing | losikid | Tools, and Procedures | 12 | 11-08-2010 12:21 PM |
