05-04-2014, 09:08 AM | #21 | |
| Re: Upgrades really needed? Quote:
The stock trans cases work fine but I always heli-coil the mounting holes since they wear out quickly. Again cheap, simple and effective. | |
05-04-2014, 10:03 AM | #22 | ||
Alloy trans cases don't eliminate stripped holes they just last longer before they strip. I have threaded inserts for my next stripped trans. As of now they all have 6/32 screws holding them in the rigs. Those threads grip far better than wood screws or 3mm. | ||
05-04-2014, 12:47 PM | #23 | |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
I will have to look into the heli-coil method or 6/32 route I really like the bullet proof trans by super shafty.........but I can't justify spending 200 on it......and needing 2 of them for two rigs | |
05-04-2014, 02:43 PM | #24 | |
Quarry Creeper Join Date: Nov 2013 Location: California
05-04-2014, 03:09 PM | #25 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Upgrades really needed? Never considered inserts to fix my stripped cases, are you going to use 6/32 inserts or would a 3mm insert work?
05-04-2014, 03:30 PM | #26 |
| Re: Upgrades really needed? I use 6/32 screws in the stock holes, no inserts needed so far. I do have 3mm and 4-40 inserts in the bolt tray at the ready for next time I rip a trans off the mount though. |
05-04-2014, 04:48 PM | #27 |
Calderwood, do you have a link for which heli-coils you use? I looked on their site but not sure which ones, definitely interested in those. Thanks Cheers, Wade |
05-04-2014, 05:00 PM | #28 |
| Re: Upgrades really needed? I use m3 stainless heli-coils. I buy them in bulk on eBay. You don't need heli-coil brand. You just need them to be compatible with the heli-coil tool. You may find them cheaper if you search "thread repair" or "thread insert" on eBay. Its been quite a while since I have bought any.
05-04-2014, 05:56 PM | #29 |
Ok, thank you, I will definitely look into these Thanks again Cheers, Wade |
05-04-2014, 06:04 PM | #30 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
I'm a firm believer in upgrade as u break unless u only break the part because it's been on your truck for a year of abuse. With my rig I HAVE upgraded literally every single part. This is because I HAVE broke just above every single part at least once. My most current upgrade was pretty much out of necessity. After breaking my plastic axle cases again, the 5th time on the front and 3rd on the rear. I felt is was time to stop spending $13, about every month for another plastic axle case, and buy some metal axle cases. I CHOSE TO DO THAT and spend almost $500 for currie axles and links. All the parts on my truck have been replaced by upgrades after the previous part was broken, usually more than once. The only exceptions are aesthetic parts I.e. beadlocks. When I first got into crawling I was a idiot and threw money at my first scx thinking it was the $h!t. I can tell u it was the biggest p.o.s. ever lol. Just because your truck is fully upgraded does not make u a better driver. Upgrades don't make a big difference, experience does |
05-04-2014, 06:16 PM | #32 | |
05-04-2014, 06:49 PM | #33 |
| Re: Upgrades really needed? No I haven't but I know people that have and it worked. So far the 6-32 stainless allen flat heads have worked perfectly. I drilled the skid plate holes a bit larger so the screws would pass through without threading themselves in and it's been great ever since. The inserts are my backup/backup plan. |
05-04-2014, 07:24 PM | #34 |
These are some great suggestions guys, they will help out a lot of folks. Keep'm coming. But dam it, I keep eyeing up that super shafty trans Cheers Wade Last edited by Wade; 05-04-2014 at 07:47 PM. |
05-05-2014, 03:38 AM | #35 | |
The "need" can be because a part is broken or it can be because it performs worse than desired (servo too weak, for example). The main differences between "X" and for example Axial are: 1. The number of parts you eventually need to replace. (Unless you abuse the truck beyond intended use.) 2. The amount of spare and optional parts available. There's plenty of original and 3rd party options available for Axial, but upgrades for the "cheap" brands are just about not available. | |
05-05-2014, 04:45 AM | #36 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
Really like the inserts, never thought of it myself. I don't find any M3 on Ebay. Any help will be apreciated.
05-05-2014, 08:18 AM | #37 |
| Re: Upgrades really needed? I just searched "m3 heli-coil" on eBay and got 87 results. That doesn't happen for you? Like I said above you could also search "thread repair" or "thread insert" instead.
05-05-2014, 09:42 AM | #38 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
I tend to overbuild my rigs because I fly to comps. Spending another $40 to get a quality part is cheap compared to flying 2000 miles to have something break on you during the first course. If I was building a rig to play around with close to home I'd use the fix it if it breaks method |
05-05-2014, 09:56 AM | #39 |
I also believe in upgrading as you break things, but I also believe in learning from your experiences. For example, if you own multiple AX/SCX based trucks and have broken your C's and Knuckles multiple times on one, it's probably safe to say you will eventually break all of them. I won't waste time building a new axle without upgraded C's and knuckles because I know they will break on me. It's not worth it to be the one who goes home early, because of a broken part that I know is going to break. |
05-05-2014, 10:05 AM | #40 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
In my experience, beyond the requisite knuckles & c-hubs--which break when you breath on them, front universals, and upgrading the linkages, I haven't really upgraded very much on my rigs. Even when I did comps, my ancient Sportsman AX10 didn't really get much other than what I mentioned above, and everything except the links on that rig went on to an Eclipse tube chassis and Bastard tube chassis (remember those?!), then back to a BWD SSS-R torsion chassis, and finally became an SCX10 before it got sold off. That was about 2 years without any breakages other than what I mentioned. My SCX10s never got anything beyond metal linkages if they didn't come with them already. But I do tend to drive those trucks in a "scale" fashion, reversing as many times needed to clear an obstacle, not giving it full throttle when I clearly see it is wedged between rocks, and *gasp* winching my way out like I would if I were driving my real Jeep. I remember doing a scale run on a trail where we spent 10 minutes rigging up a complex winching system using the flimsy bushes that were around, and then a kid rolls up and says, "why don't you just pick it up?" I've seen the most breakages to date with TTC style comps, Ultra 4 style rock races, and FOFF builds. |
Upgrades really needed? - Similar Threads | ||||
most needed upgrades for baja 5b? | Rc_Kid | Non Crawler RC's | 5 | 09-12-2009 06:48 AM |
