05-05-2014, 12:27 PM | #1 |
Newbie Join Date: May 2014 Location: BR
| Helpful insight
Just joined forum but I have been lurking in the shadows for a while. Looking for any and all advice. I have a axial rubicon converted honcho running 2.2 flatirons with novak eiger pro on 3S (love this little esc the adjustments are great). Ran motors as follows. 1 Axial 21T/27T- Quick impression-cheap, not enough torgue for debris (leaves, pin straw) covered hills. Not enough wheel speed for slinging mud. 2 Axial 55t- Strong on 3S but cheap as expected from a 55T not enough wheel speed for sling mud 3 Novak rockstar 35T- ran hot probably due to user error/improper gearing. Good strong motor, but overpriced. 4 Integy lathe 35T- good motor for a decent price but runs hot (17/87 gearing)(2.2 tires and about 8.4lbs) With this in mind thinking of 13/87 on a Orion modified 21x2 motor.. Will this give me my speed but still allow torque for crawling over roots etc? I also have a AX10 with a Tekin FX-R (also a sweet little esc) running 2.2 HPI rock grabbers. Cant decide on what motor to use and having a problem when in a jam for torque the passenger side front tire kicks up in the air while the rear drivers side digs in wanting to do a back flip??? FYI I have also been on a journey trying every bit of grease/oil for crawlers (bearings mainly) in wet conditions. Best-Acergoo for bearings, eureka pro lube for gears aeroshell 33 on anything with metal to metal contact (CVD) and royal purple synfilm (also a great lube for speed bearings maybe better than acer SIN) on joints, pivot points. Sorry for being so sporadic.... excitement and OCD... |
05-05-2014, 07:19 PM | #2 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
| Re: Helpful insight
Try dropping the gear ratio on the 35t, I run one in my 2.2s and it has a good mix of speed and torque. Only issue I have is it really draws the mahs.
05-06-2014, 07:06 AM | #3 |
| Re: Helpful insight
I tried a 13T pinion but it lacked the speed I was looking for. Not sure how well the Orion would do as its more for touring not crawling but would like to give it a go without destroying it.
Helpful insight - Similar Threads | ||||
need some insight please? | 88gmchog | Newbie General | 2 | 11-28-2009 09:01 AM |
new and need some insight please | pontiacfreak | General Crawlers | 2 | 11-20-2009 10:05 PM |
Would appreciate your insight | jaxcoffee | Missouri | 4 | 03-05-2008 12:10 PM |
Willing to share some insight? | jaxcoffee | Minnesota | 1 | 03-03-2008 05:55 PM |
