05-08-2014, 03:11 PM | #1 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
| Need a measurement - WRAITH UNIVERSAL?
Can any of you Wraith people hook me up with this dimension? Pretty please! Center of pin to the end of the shaft. For the Long & Short shafts. Thanks! |
05-08-2014, 03:33 PM | #2 |
| Re: Need a measurement - WRAITH UNIVERSAL?
Long - 125mm I don't have a sort shaft out that isn't broken. |
05-08-2014, 04:40 PM | #3 |
Dang, too short. Oh well. Thanks for the info!!
05-08-2014, 04:42 PM | #4 |
| Re: Need a measurement - WRAITH UNIVERSAL? |
05-08-2014, 04:47 PM | #5 |
Modify long shafts for use in a super axle.
05-08-2014, 04:48 PM | #6 |
05-08-2014, 05:15 PM | #7 |
Im open to suggestions. Got any examples i can peak at? Only stipulation is that they have to be compatible with wraith chubs and knucks. Last edited by TURBOFEST; 05-08-2014 at 05:20 PM. |
05-08-2014, 05:29 PM | #8 |
| Re: Need a measurement - WRAITH UNIVERSAL? I don't know of any that will work directly with the wraith knuckle. I plan on making a conversion bushing to replace the inner knuckle bearing on wraith knuckles so that the 1/8 scale stuff fits. Otherwise you would have to go with dlux knuckles which are a great deal if you don't already have knuckle weights.
05-08-2014, 05:36 PM | #9 |
Need to use wraith c-hubs. If another knuckle will work with them, that fine. I dont need knuvkle weight cause they will be in the rear. I have the front axle covered with 300hd builders.
05-13-2014, 03:06 AM | #10 |
| Re: Need a measurement - WRAITH UNIVERSAL? Dlux V2 knuckles can be made from delrin, and will work with wraith chubs. And he makes them to accept Ofna stubs. You just need o find an Ofna shaft that is long enough, which I'm not sure they do.
05-13-2014, 12:59 PM | #11 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
If you are willing to go non 8* you could have axial sxc chubs and bully v1 knuckles. They will work with the 1/8 stuff. |
05-13-2014, 01:07 PM | #12 |
I think, for now, I'm gonna be going with some frankenaxles using wraith unis, Super Bully inners and a welded sleeve. It'll buy me some time to figure out a more presentable solution for the long term.
Need a measurement - WRAITH UNIVERSAL? - Similar Threads | ||||
Need a measurement from a wraith owner | Killa-Cotton | Axial Wraith | 2 | 02-06-2013 05:21 PM |
Need a quick measurement, don't have my wraith with me | dunerinaz | Axial Wraith | 5 | 12-03-2012 05:11 PM |
Wraith measurement question | KDZ76 | Axial Wraith | 0 | 09-12-2011 05:17 PM |
