06-07-2014, 08:26 AM | #1 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
| How Much Is Your Time Worth?: New Fab Tab designs!!
We've added two new Fab Tabs to our lineup of fabrication tabs for the DIY builders out there. All our tabs are designed to take the headache out of the most tedious part of custom fab work. First up is the new "axle truss" Fab Tab. Designed for use with the SCX axle housings. It utilizes both bolt holes in the housing and the added "ear" allows perfect alignment for tubing everytime. Making a 4 link truss or other axle mounted items is a breeze with these. They can also be use for scale bump stop pads or anything else you can fine them for as far as placement. Next up is the new "light bar" Fab Tab. Designed to add Ultra4 styling to any custom chassis with ease. Probably one of the most difficult and time consuming tabs to make by hand and keep perfect. That's a thing of the past now! Designed around the large Axial oval light buckets and will house 4 units. Tab dimensions are: 5.062"x .562" and can easily be modified due to its steel construction. Available at www.carterfabmachine.com, and don't forget we have discount codes for bulk purchases. You can also mix and match FabTabs and still use the discount codes. |
How Much Is Your Time Worth?: New Fab Tab designs!! - Similar Threads | ||||
Fab Tabs: How much is your time worth? | CarterFab | General Crawlers | 74 | 02-18-2018 07:07 AM |
J-fab designs | MR.VERTICAL | EnRoute Berg | 229 | 10-26-2013 10:09 AM |
Rebuilding Frankenstein to J-FAB Designs CF | MR.VERTICAL | Axial AX-10 Scorpion | 49 | 02-02-2013 07:54 PM |
JRock's J-Fab designs berg build | JRock | EnRoute Berg | 30 | 04-15-2011 09:39 AM |
