06-09-2014, 07:36 AM | #1 |
Rock Stacker Join Date: Oct 2012 Location: Barbados
| What grease to use in shocks
Hi, I bought a new set of Sawback Shocks from a member but it did not come with the grease. What type of grease should I use which is safe on the O rings. Thanks Prem. |
06-09-2014, 08:05 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: What grease to use in shocks Green Slime This is the most popular among the racers I know. I have never greased anything before I assemble, I just oil the o rings before I put them together. And just to clarify, your not wanting to pack the shock with grease? |
06-09-2014, 08:44 AM | #3 |
Well no. The sawback shocks are oil less shocks and it comes with a grease. I received them without it. I just don't want to put the wrong type incase it damages the O rings. |
06-09-2014, 05:08 PM | #4 | |
| Re: What grease to use in shocks Quote:
I would say damn near any grease should be ok in that application. I have been using the same jar of Redline synthetic grease for the last 8 years. It does not swell o rings that I have seen. | |
06-13-2014, 12:53 AM | #5 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
Just a quick question. Are these shocks any good? Except for the old crappy tamiya friction shocks I have never used oiless shocks.
06-13-2014, 04:47 AM | #6 |
Will let you know this weekend. I will assemble them and test them out. I like them cause the springs are soft. Since the springs are internal, they were meant to be used with leafs. I will however use them as a semi droop set up. Prem. |
06-13-2014, 07:32 AM | #7 |
Pebble Pounder Join Date: Nov 2013 Location: Bedford, Nova Scotia, Canada
It still blows my mind that so many manufacturers that make scale rigs (ESPECIALLY Axial) can't make oil-filled shocks that DON'T leak!!!! But, I've heard that some friction shocks actually work well for trail running applications. As for your question, another suggestion is silicone grease. Shouldn't attack the rubber o-rings (as many shock oils are silicone-based). |
06-14-2014, 12:29 PM | #8 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
To be fair even 1:1 coilovers leak thats why they can be rebuilt just like ours.
06-14-2014, 01:23 PM | #9 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Gmade shock grease
What grease to use in shocks - Similar Threads | ||||
Universal axles (Axial)... grease or no grease | TacoCrawler | Axial SCX-10 | 15 | 11-14-2013 12:27 PM |
Axle grease, grease gun idea. | arctichorse | Axial SCX-10 | 1 | 11-14-2012 11:52 PM |
