07-02-2014, 04:18 PM | #1 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| I'm getting confused with gearing
Ever since it started getting hot here in Alabama, I have been going on a rollercoaster with the gearing on my Wraith hybrid. Specs: Hyperion 6.5T sensored motor MMP 3300mah 3S 50C lipo Mickey Thompson 2.2 TTCs (5.75" tall) 38/13 axle gearing right now (Moving to Overdrive in the front later this week) Right now, my pinion and spur gearing is 54/12 (32P) which equals 40:1; WAYYY too overgeared. After about 10 minutes of calculating some gear ratios, I have come up what I would think would be a good gearing combo, actually 2. -Scenario 1 58/17= 3.4117 *3 Transmission ratio *2.92307692 Axle ratio 29.9185:1 -Scenario 2 54/18= 3 *3 *2.92307692 Axle ratio (38/13) 26.3076:1 So, are any of these scenarios in the ball park? Or do I need to work closer to a lower final drive ratio? Thanks for any help! Last edited by Lentsnh2012; 07-02-2014 at 04:23 PM. |
07-02-2014, 04:32 PM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: I'm getting confused with gearing
with that motor more 60/12 or 58/11 or a 9 or 10 tooth just mt 2cents
07-02-2014, 04:51 PM | #3 |
A 58/11 combo would increase the final drive ratio to 46.2377 (motor revolutions to one rotation of the tire) which is higher than what I'm currently running.
07-02-2014, 05:42 PM | #4 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| Re: I'm getting confused with gearing |
07-02-2014, 05:50 PM | #5 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
Im running 57/11. Seems to be the sweet spot
07-02-2014, 07:31 PM | #6 |
66/11 on 4s! |
07-02-2014, 08:09 PM | #7 |
07-02-2014, 08:39 PM | #8 |
Okay, I think I've got it squared away. I was going to wrong way with my spur gear. With the gearing I have available, I can do a 54/8 or 54/10 54/8=6.75 6.75*3=20.25 20.25*2.92307692= 59.1923:1 Final drive gear ratio. Too low maybe? 54/10=5.4 5.4*3=16.2 16.2*2.92307692=47.3538:1 |
07-03-2014, 04:19 PM | #9 |
I would try the 54/10
07-05-2014, 10:23 AM | #10 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
I run mostly 16/87 and it depends what motor you have. You need to keep a eye on the temp of the motor. If too hot, hear gear down to a lower pinion.
07-05-2014, 12:11 PM | #11 |
87/16 is the same as 54/10, 32p is more durable however. I've found as well that anything between 5:1-6:1 at the spur/pinion is about right for an axial drivetrain.
07-05-2014, 01:07 PM | #12 |
07-05-2014, 03:04 PM | #13 |
The axial transmission is 2.6:1. Not the 3:1 that you keep doing your math with.
I'm getting confused with gearing - Similar Threads | ||||
So confused!!!! | 0volts | Newbie General | 11 | 12-26-2009 09:50 PM |
I am confused | MirrorCarp | Newbie General | 9 | 01-25-2009 08:07 AM |
confused | demonoid369 | General Crawlers | 4 | 12-05-2008 10:00 PM |
ok im confused | cloddyman | Electronics | 5 | 03-13-2007 09:20 PM |
I am confused!! | JeeperoManiako | Chit Chat | 6 | 10-10-2006 01:22 PM |
