08-10-2014, 05:13 PM | #21 |
Pebble Pounder Join Date: Feb 2014 Location: gladwin
| Re: Axial wraith kit
Neon green or black any ideas military or ken block I was in the military and I am a huge ken block fan
08-14-2014, 04:17 AM | #22 |
All Robinson racing gears in the transmission and spur gear now to button up |
08-14-2014, 08:42 AM | #23 |
| Re: Axial wraith kit |
08-14-2014, 08:58 AM | #24 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Let's call it tactical and leave the cage black. ;)
08-14-2014, 05:09 PM | #25 |
Cage is black and all together now I have an issue I used integy steel drive shafts and the pinion gear is not making contact with the beval gear
08-14-2014, 06:59 PM | #26 |
08-14-2014, 07:01 PM | #27 |
I am slow some times I forgot to put the pin in
08-15-2014, 08:11 AM | #28 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
So you worked out the shafts bro? I was at a loss for sure. Hope your good now!
08-16-2014, 07:05 PM | #29 |
Yep then I burned out the esc trying to hook up a BEC
08-16-2014, 11:51 PM | #30 |
08-21-2014, 02:18 AM | #31 |
| Re: Axial wraith kit She is built and she is mean so far I have broken a drive shaft and CVD axle. So now I have to wait until I get back from NYC to get a set of mip drive shafts. Sent from my iPhone using Tapatalk |
08-21-2014, 02:49 PM | #32 | |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Re: Axial wraith kit Quote:
I put a Team Orion Method Pro 20T brushed motor in mine. Basically a higher-quality version of the stock motor. Thus far I like it; it's a little faster and makes noticeably more torque than the stock motor, and it doesn't need any fancy electronics to make it run smooth. This is true. Changing ESCs on some of my vehicles almost completely eliminated the cogging they used to exhibit. Still, a motor will run smoothest if the power distributor knows exactly what the spindle's rotational position is at all times. Sensored brushless motors do that electronically, and brushed motors do it mechanically with the commutator. Sensorless brushless will never, ever be as smooth, though it does have the best performance-per-dollar ratio of the three options. Last edited by fyrstormer; 08-21-2014 at 03:23 PM. | |
08-21-2014, 03:19 PM | #33 |
08-21-2014, 03:21 PM | #34 |
| Re: Axial wraith kit Don't feel bad. I burned out my ESC doing something much simpler. All I had to do was solder the freaking battery plug on with the correct polarity, and I didn't even do that right. 75 dollar careless mistake.
08-21-2014, 04:01 PM | #35 |
Castle is sending me a new one and the reason I am running a 3800 kv motor is because I run open class so the faster I get over the rocks I can keep up with them Sent from my iPhone using Tapatalk |
08-21-2014, 08:11 PM | #36 |
Looks great!
08-21-2014, 09:25 PM | #37 | ||
I guess I'm gonna have to put a video together to prove my point... | ||
08-22-2014, 01:00 AM | #38 |
Videos are always fun. *makes popcorn*
08-23-2014, 08:09 PM | #39 |
Alright so I think when the esc shorted it caused the motor take a crap I freaking almost want to chuck the the thing Sent from my iPhone using Tapatalk |
Axial wraith kit - Similar Threads | ||||
axial wraith kit | vito | Newbie General | 35 | 08-04-2013 04:22 PM |
Axial SCX-10 kit or Axial Wraith kit for FOFF | rcrawler13 | Formula Offroad | 3 | 05-27-2012 05:56 AM |
