10-01-2014, 02:07 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| Link setup question
Ok so i currently have my scx10 links setup to where they have been for a while with the body that i have and i recently was told that if i swap them my truck would handle better. I have really long links up front and short links in the rear. is there really a benefit of having short links up front and long links in the rear? I will post up some pics in a second
10-01-2014, 02:08 PM | #2 |
| Re: Link setup question the front of the truck is on the right side of the pic
10-01-2014, 04:48 PM | #3 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
It will probably (not enough info to say for sure) give more front weight bias, lower anti squat number and a more desirable line of force.Another 4 Link Thread |
10-01-2014, 09:37 PM | #4 |
Rock Stacker Join Date: Jul 2014 Location: Littleton
By moving your front axle away from the cog with the longer links you have moved your front to rear bias forward also. Imo that helps with your break over point which is good. But then I run an moa with the battery mounted over the front axle so what do I know.
10-01-2014, 10:18 PM | #5 |
RCC Addict Join Date: Aug 2007 Location: Seattle
That setup is all TURTLE runs and it works for him. Let it buck. |
10-01-2014, 10:23 PM | #6 |
Thanks for all the input guys
Link setup question - Similar Threads | ||||
4-Link Setup Question | essence25 | Axial AX-10 Scorpion | 5 | 04-09-2012 02:16 PM |
link setup help | klimb2xs | RC4WD Bully | 6 | 03-06-2012 06:58 AM |
4 link setup | craveman85 | Losi Mini-Rock Crawler | 1 | 04-15-2010 09:19 PM |
Link setup on TCS 4 link plates and boulder chassis | sdcrawls | Axial AX-10 Scorpion | 8 | 11-17-2009 02:37 AM |
Link setup question... should be easy.. | BigJay | Tamiya Clod Buster | 10 | 08-10-2005 12:12 PM |
