Thread: i need a quick answer
Old 12-07-2006, 02:54 PM   #1
Default i need a quick answer
Does revo shaft's fit on a stampede nitro gearbox??
I plan to use it as a transfercase in my new crawler.
Quick answer is what i need.
Magnus
skogsvild is offline   Reply With Quote
Old 12-07-2006, 03:00 PM   #2
Magnus
Yup sure does and if it doesnt then you can modify it to fit
Gula is offline   Reply With Quote
Old 12-07-2006, 03:02 PM   #3
MAKE IT WORK, just like everything else.
and what he said.
Double J is offline   Reply With Quote
Old 12-07-2006, 03:05 PM   #4
YEAH but what i wonder is if outputs are a direct fit?
If the are bigger size then it's no mach to make the revo shaft to fit but if the outputs are smaller then its little harder to fit the revo's.
Old 12-07-2006, 03:11 PM   #5
If we can get Revo's to fit on Stealth trannies I'm sure you'll have no problems.
Old 12-07-2006, 03:13 PM   #6
Ok then.
I make it work when i got it. Thx for the aswer's
Old 12-07-2006, 03:14 PM   #7
If you were a bit more specific about it being a direct fit that would have helped you out a little more.
