01-13-2015, 04:21 PM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| crosspin on junfac driveshafts breaking
So I have had 3 of the small pins inside the head of different JunFac shafts break over the course of a few weeks, what should I replace them with? any rod of the proper size? Ace is the place for most of my odds and ends like this, just dont know if there is a better option out there? L.R. |
01-13-2015, 04:35 PM | #2 |
Newbie Join Date: Aug 2014 Location: Clovis
I would find wheel pins that fit the diameter and Dremel them to the exact length, still allowing you to use the retention ring. If you go with "any rod" that come in the 3' lengths you might run into the same problem because the metal isn't hardened. I ran into it a lot using those rods in the diffs on my savage flux hp. I found wheel pins, ground them to the perfect length and haven't broken any since. Hope this helps.
01-13-2015, 05:04 PM | #3 |
| Re: crosspin on junfac driveshafts breaking
thanks, now can ya tell me what the hell a wheel pin is? lol and where can I find one? I certainly don't mind cutting things down- L.R. |
01-13-2015, 05:30 PM | #4 |
Pebble Pounder Join Date: Apr 2011 Location: Dundas, Ont, Great White North
I assume he means the little pin that fits in the hex at the end of your axle, holds it on. It looks plenty hard to me.
01-13-2015, 09:14 PM | #5 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: crosspin on junfac driveshafts breaking |
01-15-2015, 10:08 AM | #6 |
Sent Gunnar a PM, havent heard from him yet. L.R. |
01-16-2015, 03:03 PM | #7 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
More importantly why are they breaking? I've ran Junfacs for lots of miles without breaking the pins, I've lost my fair share but never broken them. If I were to guess, I'd think your pinion angle is too steep..?
01-21-2015, 09:11 PM | #8 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
You could also find a set of cheap drill bits at harbor freight and cut the end that goes in the drill to make new pins.
01-22-2015, 12:51 AM | #9 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
01-22-2015, 04:23 AM | #10 |
crosspin on junfac driveshafts breaking - Similar Threads | ||||
Junfac Driveshafts | CamposZac96x | Axial SCX-10 | 7 | 11-30-2013 07:00 PM |
junfac driveshafts | MonsterTruckMan | Axial SCX-10 | 13 | 01-01-2012 05:17 PM |
Junfac driveshafts in!!! | sliceofnoob | Axial SCX-10 | 3 | 07-09-2011 05:24 PM |
I keep breaking the front driveshafts. why? | hambyl88 | HPI Wheely King | 16 | 10-21-2010 03:27 PM |
breaking driveshafts | tundrafan01 | Axial SCX-10 | 2 | 06-17-2010 06:37 PM |
