04-20-2015, 09:17 AM | #1 |
Newbie Join Date: Aug 2014 Location: Afame
| Narrowing wraith axles.
What kind of glue are you guys using to bond the housings back together after cutting them? Thanks
04-20-2015, 02:33 PM | #2 |
Pebble Pounder Join Date: Dec 2013 Location: spring creek
| Re: Narrowing wraith axles.
(i havent done this but heres several things you could use) JB weld Shoe goo Super glue |
04-20-2015, 02:59 PM | #3 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: Narrowing wraith axles. I use a 2 part golf shaft epoxy. It's not totally brittle when cured. No matter what you do you'll need an internal tube to support the housing after cutting. I've used old male drive shaft parts from an scx10. Others have used beef tubes (cut down) or made their own tubes out of brass/Al/Steel.
04-20-2015, 10:26 PM | #4 |
All the help is greatly appreciated! Thanks
04-21-2015, 06:29 AM | #5 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Narrowing wraith axles. Use a inner tube Drill and tap it both sides " four total screws" you will be bullet proof.. |
04-21-2015, 07:12 PM | #6 |
RCC Addict Join Date: May 2013 Location: York, PA
Here's another option. Depending how narrow you want to be, I took 1/2" off my sportsman without cutting the tubes at all. Ugly Betty |
Narrowing wraith axles. - Similar Threads | ||||
Narrowing scx-10 axles? | 93 FORD BRONCO | General Crawlers | 9 | 07-20-2012 07:39 PM |
Narrowing Rear, Axles? | RcBro | EnRoute Berg | 16 | 02-03-2010 09:53 PM |
Narrowing the axles? | mmbackpacker | Axial SCX-10 | 7 | 07-12-2009 06:56 PM |
Narrowing SCX10 axles? | Sasquatchbagger | Axial SCX-10 | 6 | 04-10-2009 12:36 PM |
narrowing WK axles | jetboat | HPI Wheely King | 11 | 10-20-2007 11:54 PM |
