08-22-2015, 03:26 PM | #1 |
| Derlin Link Material?
I searched but could not find an answer or a link. I am looking to build some custom links out of Derlin and was curious if the below link is what everyone is using. I am going to use a Jeepindoug drill guide. Thanks for any info. McMaster-Carr |
08-22-2015, 04:03 PM | #2 |
| Re: Derlin Link Material?
Wanna be more specific other than a link to all their plastic choices?
08-22-2015, 04:32 PM | #3 |
My bad. I was looking at the: Wear- and Water-Resistant Delrin® Acetal Resin Considered the workhorse of plastics, Delrin® acetal resin combines moisture resistance and a slippery, wear-resistant surface with an ability to hold tight tolerances. Also known as acetal homopolymer, it's often used for gears, bushings, impellers, and other parts that require its strength and rigidity." McMaster-Carr Last edited by cmbscx10; 08-22-2015 at 04:34 PM. Reason: Link Correction |
08-22-2015, 04:36 PM | #4 |
Just ebay "1/4 delrin rod" or whatever size you are looking for and there are a few stores out there. easier and cheap setup is listed here in the two links below. AL rod tapped 8/32 and some revo rod ends. use a small pipe cutter to get your exact link length. 8/32 drill/tap is good to have, in case you have to drill further in and retap after cutting a link down. Easily under $40 for 8-piece link setup on a truck. How To: Make your own links Szczerba's Montero ... |
08-22-2015, 04:47 PM | #5 | |
| Re: Derlin Link Material? Quote:
08-22-2015, 07:46 PM | #6 |
Vanquish sells 155mm (~6.0") Ti links. I bet those paired with jato ends could get yah close?
08-25-2015, 05:54 PM | #7 |
Sorry, "derlin" not found. Delrin?
08-25-2015, 08:57 PM | #8 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
I have some black 5/16" and some 3/8" solid Delrin rod, 5' lengths.
08-27-2015, 10:23 AM | #9 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
I bought a stick of 1/4" delrin rod to make links with, and it was way to flexable. Even at around 4". I don't see it working to well on a 7" link at all. Maybe the 5/16 or 3/8 would be better, but I didn't bother to find out. I have been using 1/4" aluminum rod from home depot drilled/tapped to 3mm, and using rc4wd rod ends with axial width balls. However the rod ends keep snapping on my 10lb. Wraith. My plan is to drill/tap my links out to 8/32 threads, and make 8/32 althread couplers to use revo rod ends. |
08-31-2015, 12:33 AM | #10 | |
** I need to cut the studs to length for the Revo ends after loctite cures and give them a little sanding. ** | |
Derlin Link Material? - Similar Threads | ||||
Help with link material | Hittman | General Crawlers | 4 | 12-25-2011 10:55 PM |
size derlin link for super berg with hustler se ? | pascal | Superclass Crawlers | 1 | 05-27-2010 03:08 PM |
derlin link material | smokediver | Tools, and Procedures | 3 | 03-21-2010 05:54 PM |
derlin link material | rockslyder | General Crawlers | 8 | 07-02-2009 02:28 PM |
