01-31-2007, 08:33 PM | #81 | |
The uppers do look a good bit shorter than the lowers. Shorter upper links will roll the pinion down on droop creating a bad pinion angle. Running the same length or a hair longer uppers will keep your pinion out of the dirt | |
01-31-2007, 08:59 PM | #82 |
The shock angle is definately out of wack.
01-31-2007, 09:02 PM | #83 | |
01-31-2007, 09:17 PM | #84 |
Newbie Join Date: Jan 2007 Location: Glendora
I moved the rear upper link higher on the chassis which created some squat to the rear end. Left side of picture is the Front. |
01-31-2007, 09:17 PM | #85 | ||
yeah the shocks are abit long especially with the rod end added to the top of it | ||
02-01-2007, 05:57 AM | #86 | |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
I don't know on the torque twist it might. You don't need that much triangulation in your links. | |
02-01-2007, 02:05 PM | #87 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
| 4link calculator **Exel required http://mysite.verizon.net/triaged/fi...arLinkV3.0.zip Play with this, helped me figure things a little better. |
02-01-2007, 02:50 PM | #88 | |
too bad i dont have my crawler here with me... :-( | |
02-04-2007, 07:54 PM | #89 |
Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
ok, if you run a truck with arms backwards you do not have the traction that you do going forward. now with that being said what about the 4 link ste up? if you have you rig set with a bit of squat in the front and a bit of anti-squat in the rear and it crawles great........... FORWARD, what about in reverse? if you try to back out of a hole then you will have a front flipping turd.... right? the direction you are going has a lot to do with you link set up. what do you guys think? i know we mostly are driving forward but that one time you need to get out of trouble. |
02-04-2007, 08:38 PM | #90 | |
02-05-2007, 04:27 AM | #91 |
RCC Addict Join Date: Apr 2006 Location: Minnehopeless
| I have to say that I've learned a lot from this thread. Thanks guys. I was using a torsion chassis on my 2.2 last year so i didn't have to worry about any of this. However, this year I'm going back to a 4 link setup. So now I've been experimenting. At first I had massive torque twist and could only climb a minimum angle before flipping. I've since toyed with link angles; it's amazing how a little adjustment here and there can make a huge difference. I've taken from Cole, and tried unsymmetrical link mounts and that's made an imrovement too. For my latest testing I'm trying internal reversed shocks in the front and standard shocks in the rear. It's definetly improved my break over point, but it has also slightly improved my torque twist. If I had a decent camera I'd post some pics. Oh well, the testing continues. |
02-05-2007, 10:53 PM | #92 |
Newbie Join Date: May 2006 Location: Bay Area, CA
I found this picture while searching google and it clarified a few things for me. I found this on the same site, explains torque twist well. http://www.raceglides.com.au/TechInfo.htm |
02-09-2007, 11:02 AM | #93 |
Pebble Pounder Join Date: Nov 2006 Location: 303
How would the upper link placement on the axle effect the squat, comparing a clod where the links mount in front of the servo to a tlt where most guys run the upper links behind the servo??? The above diagram show the upper and lower links in center line of the axle
02-09-2007, 02:46 PM | #94 |
You're still going to have the dashed lines converge into a point, the instant center. Shorter links scribe a tighter arc, so maybe the instant center moves more when the suspension moves. |
02-09-2007, 04:35 PM | #95 |
Anyone want to guess what happen when I lowered the lower link at the axle?
02-09-2007, 04:43 PM | #96 |
Im gonna guess you get a bunch of squat when you peg it.
02-09-2007, 06:04 PM | #97 | |
Wait.....that is the rear of the rig right Eee Pee | |
02-09-2007, 06:16 PM | #98 |
Yeah, the back.
02-09-2007, 06:59 PM | #99 |
Two people...
02-09-2007, 09:57 PM | #100 |
I bet there are less than 10 people on this board that even know what AS is on a rig. The rest cant wrap their wee little heads around it |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/general-crawlers/54791-anti-squat-suspension-tech.html | ||||
• Afficher le sujet - Anti-Cabrage VS Torque-Twist | This thread | Refback | 10-05-2011 03:42 PM |
