11-21-2015, 02:24 AM | #1 |
Rock Stacker Join Date: Jul 2004
| Scx Diff input shaft bushing instead of bearing
I was wondering why people use a bushing on the scx-10 input shaft on the diff. I have been noticing it more and more......Thanks
11-21-2015, 09:59 AM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Scx Diff input shaft bushing instead of bearing
They don't grenade like the bearings can under big power or full throttle assaults when landing off a flight. Bushing do require periodic replacement as they are a item that wears out
11-21-2015, 12:45 PM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
...they also impart wear on the input shaft, so it will need periodic replacement too.
11-21-2015, 01:01 PM | #4 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: Scx Diff input shaft bushing instead of bearing |
11-21-2015, 01:45 PM | #5 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
I tried the bushings one time, and was not impressed. After one long day on the trails they had a ton of slop.
11-21-2015, 04:39 PM | #6 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: Scx Diff input shaft bushing instead of bearing Which ones? I get decent life out of the Traxxas ones but I tried HPI bushings and they were sloppy as hell after a couple hours. I also make sure to load up the space between the two bushings with grease.
11-21-2015, 05:06 PM | #7 |
| Re: Scx Diff input shaft bushing instead of bearing In an off-road RC environment is doesn't take long to wear the bushing or pinion shaft to the point they should be replaced. I've seen front/rear steel axles and aluminum steering posts on buggies and stadium trucks get ruined in a day driving in the dust pit we had to drive in. Fine sand can eat through them pretty quick too.
11-21-2015, 05:52 PM | #8 |
| Re: Scx Diff input shaft bushing instead of bearing I used the traxxas bushings. I still have a bunch of them in the toolbox that I will probably never use.
11-23-2015, 07:28 AM | #9 |
I have sold a TON of Wraith axles with my upgraded 13mm bearing (instead of 11mm) and had very, very good success. I also sell the AX/SCX housings with the same mod and have had zero failures that I know of. Check them out. I think you will be amazed at the difference they make. https://dluxfab.ecwid.com/#!/Modifie...egory=12405706 Last edited by Erik D_lux; 11-23-2015 at 07:30 AM. |
Scx Diff input shaft bushing instead of bearing - Similar Threads | ||||
Spektrum S605 servo output shaft bearing/bushing sizes? | Natedog | Electronics | 1 | 10-11-2017 12:11 PM |
Ascender 5mm Diff Input Shaft Conversion | Generis | Vaterra Ascender | 17 | 01-22-2016 08:44 PM |
New Diff gears want to crunch under input shaft pressure. | Mdanylak | Axial Yeti | 4 | 06-16-2015 07:34 AM |
