01-01-2016, 06:36 PM | #1 |
Newbie Join Date: Dec 2015 Location: Nashville
| Shocks with no oil?
I got Pro line powerstroke shocks for PRO 2SC Pro 2 biggy shocks for my vaterra ascender and I fell like they may be better without oil. For more of an off-road flex usage. I may be wrong though what do yall think?
01-01-2016, 07:30 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Bloomsburg, pa
| Re: Shocks with no oil?
in the ax10 scorpion days this was a popular thing. Put a little in just for some lubrication. I dont know how it would do with a scale crawler though. Maybe just use super thin oil?
01-01-2016, 07:33 PM | #3 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Oil doesn't affect "flecks".
01-01-2016, 07:42 PM | #4 |
| I don't know what you're saying with "flecks". I feel like you don't understand the question. Alright thank you onebullet. I think I'll fill it up halfway or something. Last edited by THX_138; 01-01-2016 at 08:29 PM. Reason: Repeat posts seconds apart , merge |
01-01-2016, 07:51 PM | #5 |
Flex.... Oil weights affect rebound. Shocks with no oil are just springs. Half oil is really just as silly. Especially if you've already went the extra mile to buy quality shocks. There's many thin weights to be explored really and different piston hole combinations to be used. For crawling I use 2 hole pistons and 40-50wt. For something like u4 and mix I use 2 hole and 30-35wt oil. Last edited by THX_138; 01-01-2016 at 08:31 PM. |
01-01-2016, 07:53 PM | #6 |
Gotcha I'm sorry about that Mike I thought you were trying to be smart about it haha. I see what you're saying though. I just figured that the oil would make them stiffer but I forgot about the spring adjustment.
01-01-2016, 08:03 PM | #7 |
| Re: Shocks with no oil? there are multiple forms of rebound some of which would relate to "flex" no, if you ran just springs you would get alot of side to side movement out of the axle. Not using oil does take a component out of having a shock obviously but people have done this before and for awhile it was somewhat of a standard thing. Another option is forced droop via internal springs |
01-01-2016, 08:09 PM | #8 | |
Well I didn't say with no shafts or suspension links..... I am aware of usage by previous newbs and no oil and have myself ran with internal springs for limiting and droop. I'm not arguing. Hell I ran axle grease in some cheapo plastic Losi mrc shocks once years ago because they were so leaky and sloppy. Oil weight does not affect flex. It will just let it get to full flex faster or slower. Period. Guess it depends on your terrain and handling characteristics you want is what it boils down to. "Newbs" was a strong word.. I'm sure it was the standard for that time and situation because it worked best for the trucks and terrain. Last edited by THX_138; 01-01-2016 at 08:32 PM. | |
01-01-2016, 08:16 PM | #9 | |
| Re: Shocks with no oil? Quote:
for a comp crawler enough to raise a tire almost over tire height is pretty much the max you want. If you are using a scale rig doing that would be in the too much area. | |
01-01-2016, 10:22 PM | #10 |
I just don't want it to be stiffer than a brick haha. I just don't want to go over something and have every other tire up in the air. I filled them up and adjusted them now they work pretty good
01-03-2016, 10:06 AM | #11 | |
Rock Crawler Join Date: Dec 2005 Location: East Texas
OP, these guys got you squared away, ill see myself out, I'm late for church..... | |
01-04-2016, 10:41 AM | #12 |
I don't run oil in my scaler shocks. I like the way the suspension cycles over bumps with out it. Not bouncy at all either.. I just put about 10 drops of 30wt oil in once 'n a while to keep the o-rings happy. Doesn't hurt to try it, if you like how the truck handles, well there ya go.
01-04-2016, 06:23 PM | #13 |
Rock Crawler Join Date: May 2013 Location: Dallas
I think I just got stupider reading this thread... Let me start first by saying, there's a reason almost every RC doesn't come with friction shocks now... If these were effective, manufacturers would supply them as OEM to save money. I all seriousness. Keep oil in your shocks. Play around with oil to get the effect you want. I pay close attention to how the suspension reacts when I'm driving. Sometimes you honestly want to slow down how quick the weight transfers from one wheel to another. You'll be able to see this after driving for a while. Anyone who runs oilless shocks doesn't maintain their rig is or is driving a SCX10 with a 55 turn on 2s with 87/17 gearing. Also, keep them as full as possible without "pack" the shock should be able to fully compress once assembled with little air inside. If you push the shaft in after putting the cap on and it springs out significantly, remove some oil. The closer you can get these to "ideally" filled the more consistent the damping will be. Air will make it inconsistent as it turns from one big bubble into zillions of microscopic ones. While this is happening the only thing that can be assured is that the rate of damping will decrease. Last edited by DrewHammer; 01-04-2016 at 06:26 PM. |
01-04-2016, 06:25 PM | #14 |
Stupider how. This thread evolved and informed nicely.
01-04-2016, 08:55 PM | #15 |
Quarry Creeper Join Date: May 2015 Location: RRW
stupider isn't a word
01-05-2016, 09:08 AM | #16 | |
01-05-2016, 09:45 AM | #17 |
Quarry Creeper Join Date: Dec 2015 Location: United States
| Re: Shocks with no oil? it is, it's the comparative form of stupid. stupider, stupidest, stupidly, stupidity and stupidness are all words in the English language. a few just don't sound right for some reason. dumber, dumbest, more stupid, these sound correct but stupider is also correct
Shocks with no oil? - Similar Threads | ||||
No oil in shocks | JCO245 | Losi Mini-Rock Crawler | 6 | 02-24-2010 03:08 PM |
shocks and oil | siriussr | Axial AX-10 Scorpion | 5 | 07-18-2008 03:37 PM |
need help with oil shocks | Gekopro60/40 | Newbie General | 7 | 03-02-2007 09:47 AM |
No oil in shocks? | chevellian | General Crawlers | 17 | 12-29-2006 05:54 PM |
