01-05-2016, 04:09 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
| P-L Power Strokes..am I missing something?
Yet another pesky question....well two actually. First question-bought a set of Power Stroke Slash rears, installed oil and found them to have a "dead" spot where the shaft could easily slide in/out 1/8 to 3/16" or so before getting any dampening action, I found the piston would float on the shaft, the lock nut wasn't tight against the piston and it could move freely-the fix was obvious. Second question-I had intentions of installing these on a Wraith and found the shock caps wouldn't accept any ball's I had (insert joke here) Am I missing something? Should the piston float on the shaft? Is there a bushing you guys use in the shock cap? I hesitate to drill the hole out to fit a ball, but if that's what is expected I'm good with that. |
01-05-2016, 04:43 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Dallas
| Re: P-L Power Strokes..am I missing something?
Proline sells a mount kit, or I believe you can use slash shock balls for it. Although don't quote me on that specifically. PowerStroke SC Universal Shock Mounting Hardware Kit | Pro-Line Racing I drilled mine long before the kit came out. It works but it's far from ideal. The piston should not float on the shaft. It's been a while since I've had mine apart, is there an e clip on the bottom? |
01-05-2016, 05:07 PM | #3 |
No e-clip, just a shoulder, washer, piston, washer and nut, the shaft threads were barely to the nylon in the lock nut! I think I'l just drill em, I don't think I'l have to remove too much material. |
01-05-2016, 05:41 PM | #4 |
| Re: P-L Power Strokes..am I missing something? I barely bumped mine with whatever the next size up in my index was correct. I want to say it was 1/4, maybe a size F. It's been over 3 years since I've done this. I just measured the OD of the shoulder on wraith shock bushings and made it just slightly smaller than that.
01-05-2016, 05:46 PM | #5 |
I use fuel tubing as a bushing on shock caps without built in ball cups.
01-05-2016, 05:49 PM | #6 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: P-L Power Strokes..am I missing something? |
01-05-2016, 06:40 PM | #7 |
Fuel tubbing: good idea! Sent from my Jitterbug |
P-L Power Strokes..am I missing something? - Similar Threads | ||||
Power Strokes for Savage | DirkDigler | Chit Chat | 2 | 06-30-2005 02:25 PM |
