01-22-2016, 02:46 PM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| LCC or AX10 base for shafty?
Hey up folks, So , I'm dangerously close to receiving my UGC Fastback chassis - stuck in customs :-( - but hopefully pick it tomorrow! Now I need to decide which way to go with the build.... Ive got an old ax10 scorpion and I've also got a losi comp crawler which I've never ran due to some issues and the usual time restraints.... So both are possibles. The Fastback was originally designed around the ax, but I understand many have successfully used the lcc. They've both got their pros and cons. I imagine the ax tranny will be lighter - but obviously don't have the dig system and worms.... What have folk used or recommend? |
01-22-2016, 04:11 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: LCC or AX10 base for shafty?
Dig can always be added to the AX10 trans (VP hurtz dig and the DNA one) are two of the better ones. The AX axles can run the available Over and under drive gear sets, not to mention parts support for the AX platform is still huge. If you intend to run Sporty class, I dont believe dig is allowed, so thats where I would recommend the Over and under drive gearsets with the Axial base as they offer a significant performance advantage. Both great platforms though, do some reading of other peoples builds on each and that might help you decide. |
01-23-2016, 07:04 AM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
I have an LNC on a FF4 chassis, and I am very happy with the performance. The biggest problem with the Losi is turning radius, even with HD gears in the front and stock in the rear. But, ever time I go to a comp, I take the Losi and leave the AX10 at home. IMO , I prefer the Losi but an AX10 with the XR mod has a lot of advantages. |
01-23-2016, 09:47 AM | #4 |
Newbie Join Date: Jun 2015 Location: Portland
I would go with the ax10 over the lcc because you'll have more part availability than the lcc and also the ax10 is going to be lighter rig. Do what ever you want but that's my suggestion(go with your gut)
01-24-2016, 04:05 AM | #5 |
Thanks chaps... I've stripped the AX10 ! Initially I was keen to use the lcc as its just such nice kit, but on reflection ultimately the ax10 will be easier for parts and most importantly be lighter... My ax was also a bit more battered... Must figure out pics at some point.... |
LCC or AX10 base for shafty? - Similar Threads | ||||
Modified Old LCC Shafty or Newer MOA Bully for a NEWB? | CreepyCrawler420 | Newbie General | 7 | 10-11-2013 07:38 PM |
Wheel base of a R1/ax10 hybrid? | ToTheMAXXcrawler | G-Made Crawlers | 7 | 06-17-2012 08:56 PM |
Bodyless chassis for shafty LCC? | Garry | Team Losi Comp Crawler | 13 | 11-20-2010 06:19 PM |
AX10 as a base for a scale trail rig? | Bansheeboy11 | Newbie General | 4 | 01-07-2008 12:08 PM |
