| | #1 |
| Pebble Pounder Join Date: Jan 2006 Location: Evansville
| I am sure this has been asked before but I need to know. What radio's are you using for your front dig set-ups. I do not want to use the TQ3. I looked on tower and some of the radios have a push button 3rd. ch. and some say the 3rd ch. is "Shift or linear dual mode third channel". What do I need? Thanks for any help, Brian |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Apr 2005 Location: Seattle
| Any radio that has a third channel that can shift will work, one with end points is a good idea for setting up a dig. |
| | #3 |
| TCS/Holmes Hobbies ![]() Join Date: Feb 2005 Location: Burnsville
| I use a JR XR3 (old model). The DX3 (not the 3.0) works much the same way, but it is a spectrum radio. |
| | #4 |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
| Dx6 |
| | #5 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| Dx6 |
| | #6 | |
| Hell's Gnome ![]() Join Date: Jun 2006 Location: I'm mean because you're stupid.
| | #7 |
| you need to do a mod to have the left gimbal self center or you can just go through horizon or your LHS, and order it that way The mod takes about an hour or less to do |
| | #8 |
| Are there any differences between planes and surface controlers? I thought I read somewhere there was. |
| | #9 |
| RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
| I use the Hitec Laser 4. |
| | #10 |
| Quarry Creeper Join Date: Dec 2005 Location: United Kingdom
| I just bought a new radio and had to have it made so that one of the sticks self centered. The part cost one pound fifty which is about 3 dollars and took about 3 minutes from start to finish. All it envolved was inserting a spring and removing a small plastic "catch" The controller I use can be used for aircraft. The difference is that in the UK the aircraft run on 35 mhz and the cars run on 40 mhz. The transmitter I am using is set for 40mhz so it is ok. If you use an aircraft frequency on your car and there are model planes within range you could cause them to crash Last edited by Tronk; 01-06-2007 at 09:05 AM. |
| | #11 |
| Thanks for the info guy's. |
| | #12 | |
If your'e on FM planes run 72MHz and ground vehicles run 75MHz. | |
| | #13 |
| ... Join Date: Sep 2005 Location: USA
| Vg6000 |
| | #14 |
| Quarry Creeper Join Date: Dec 2004 Location: Croydon, Surrey, UK
| what is front 'dig'? |
| | #15 | |
| Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
| | #16 | |
| I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| | #17 | |
| | #18 |
| I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| any radio with a 3rd channel and EPA'a will work (tq3 will with epa mods) I personally use a JR R-1 |
| | #19 | |
| Thread Tools | |
| Display Modes | |
