Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Nylint 1/6 Won't Stop
Old 01-06-2007, 08:10 AM   #1
Default Nylint 1/6 Won't Stop
Hi all.
2 of my nephews received 1/6th crawlers for Christmas. They were purchased at a flea market as new, but they are used. No chance of return so I am trying to repair them.
I have been able to figure out several problems thanx to the fine people here at RCCAWLER.com .
The scorpion won't stop moving.
I have tried both transmitters with the same result.
I found a trim pot on the main board, but it only affects the steering trim.
Any ideas?
Thanx in advance
Don_87
Don_87 is offline   Reply With Quote
Old 01-06-2007, 09:28 AM   #2
robo-3's Avatar
on my boys crawler it did that and there was a fet touching a diode on the control board in the crawler !. straightened them out and no problems since ! hope this helps !
robo-3 is offline   Reply With Quote
Old 01-06-2007, 10:47 AM   #3
Thanx for the input robo-3.
I checked the diode(only 1 there D15), nothing touching.
While I was at it I moved everything else on the board and it made no difference. Just goes straight from forward to reverse, won't stop.
Don_87
Old 01-06-2007, 11:13 AM   #4
that sounds to me like it's a trim problem. which can only mean you have chip problems! double check all wires are connecting to where there saposed to go and not grounding. if none of that pans out i suggest parting it out. and if you do i could use a front
joehein is offline   Reply With Quote
Old 01-06-2007, 11:54 AM   #5
joehein,
Thanx for the reply. You could be right about the chip problem. I've checked for anything loose or disconnected.
I'm just hoping someone else has had the problem and found a solution.
Sorry, I can't part it out, It belongs to my nephew.
I'm just trying to fix it for him.
Don_87
Old 01-12-2007, 02:35 AM   #6
everytime mine would move on its own id hit it on the bottom with a rock and it would solve it until the next time it did it
jeeperman is offline   Reply With Quote
Old 01-21-2007, 06:02 PM   #7
Smile
I HAD THE SAME PROBLEM WITH A DIFFRENT CAR . I BURNED OUT THE ESC . GOOD LUCK FINDING ONE:-( !
BRANDONB281 is offline   Reply With Quote
Old 01-24-2007, 02:26 PM   #8
does the controller have a throttle trim you can play with?
callaway is offline   Reply With Quote
