Thread: Members' Rides - No talking
Old 07-11-2007, 02:25 AM   #101
Truck Base : HPI Wheely King (Reversed Axles)
ESC: Novak Rooster (Crawler Edition)
Motor(s): Ingety 55T
Servo(s): Hitech 5645
Trans: Wheely King 96/14 Gearing
Axles: Wheely King, CVD's
Tires: Pro Line Moab, Axial Beadlocks and rock Rings, Star Cut Foams
WB: 12.5"
Overall Width: 11.5"
Diff clearance: 1.5"
Center Chassis clearance: 2.6"
Overall height: 10.5"
wshipley is offline   Reply With Quote
Old 07-26-2007, 11:13 AM   #102
Here be mine:
K2-3L
Novak XRS
Integy Lathe motor
JRst125 servo
R2 tranny
TLT axles
Pro-Line Moabs
12" WB
9 1/2" W
Diff- 1 3/8"
Center- 2 3/4"
Height- 9"
Mongo is offline   Reply With Quote
Old 08-31-2007, 02:02 AM   #103
Default Feuer's tubular
Truck Base :Tamiya TLT
ESC:Moped Bravo and Mtroniks ECO 20
Motor(s):Integy Lathe 65T Single
Servo(s):Towerpro mg 945
Trans:loocked pede
Axles:TLT-1 (loocked with ball bearings)
Tires:Proline masher 2k
WB:12"
Rainforest crawling with my first crawler
feuerradder is offline   Reply With Quote
Old 09-12-2007, 01:19 AM   #104
I joined the Band!
integy 75t motor, novak rooster crawler edition, hytek hs-645 ultra torque sterring servo, hytek aggressor srx computor radio control system.pretty much stock that may change with the availability of parts.losi rock claws on back order should be here soon. mine is the fj the willys is my sons
colonelangus is offline   Reply With Quote
Old 09-16-2007, 06:48 PM   #105
my Jeep...
Truck Base :TLT with an NN chassis and custom bent links
ESC:AI LRP runner
Servo(s):TowerPro MG995 for steering, and a basic Airtronics 94102 for the disconnect
Trans:R2 w/disconnect and punisher shafts
Axles:TLT-1 (spooled with JB in the front and CVDs, copper ring and pinion in the rear in the steel straight axles)
Tires: Mashers or Moabs on Axial beadlocks...black and black chrome
WB:13.5...I don't do the comps yet
Overall Width:11" w/GMade wideners
Diff clearance:1 1/2"
Center Chassis clearance:2"-3" (adjustable)
Overall height: just under 9 1/2"
Extras: 8 5mm super bright LEDs for night crawlin' including an adjustable spotlight........
messin around at lefthand
suspekAE is offline   Reply With Quote
Old 09-30-2007, 10:51 AM   #106
my crawler
johnathan c is offline   Reply With Quote
Old 10-11-2007, 04:02 PM   #107
Default Axial AX10
Truck Base : Axial Racing AX10 Scorpion (877493002848 )
TX: Spektrum DX7 (SPM2720)
RX: Spektrum AR6100 (SPM6100)
BEC: Castle Creations CCBEC
ESC: DuraTrax IntelliSpeed 16T Mild-Mod ESC (DTXM1065)
Motor: Integy 55T Matrix Pro Lathe Motor (SCM5501)
Batteries: Custom 16 cell 2800mah @ 9.6v (8 cells per axle)
Servo: JR 8711 Front (JRPS8711), Futaba S3305 Rear (FUTM0045)
Trans: 2.6:1
Axles: Stock
Tires: 2.2 Axial Rock Lizards
Wheels: Axial 2.2 Rockster Beadlocks
WB: 320mm
Overall Width: 254mm
Diff clearance: 79mm
Overall Weight: 5.86lbs
HawK-Z is offline   Reply With Quote
Old 10-11-2007, 04:23 PM   #108
Never posted any of mine here?
Current comp rig.
DaBULL chassis
TLT axles
Duratrax Transmission
Dampened/torsion suspension
Integy lathe 65t
Moped ESC
Erickson Beadlocks
Moabs - mashers - claws ??
weight I have no idea about, but it's all in the wheels.
On to the pics.
updated shocks since this pic.
In action.
Sons rig.
Vertical smile
TLT axles
duratrax tranny
65t lathe
moped esc
4linked
when it was mine.
Super
Clod Shaft chassis (stick inspired)
clod axles
moped
2 65t
and so on
AX-10 DaBULL
DaBULL chassis
All Axial parts (tranny, axles and wheels)
delrin links
CrawlMAX 55t from Run2Jeepn.. Awsome motor. planning on getting them for all my rigs.
moped esc
tp945 servos
Double J is offline   Reply With Quote
Old 10-11-2007, 04:56 PM   #109
Basic Set up on Both: Clod axles, Locked, CVD's, Alumn Knuckles, Alumn Axle Tubes, CrawlMax Motors, Pimp Cane Chassis, Dual Mamba Max's, Dx6 Radio Gear, 5955TG Servo's, MG945 rear servo, Castle BEC's, 11.1v Lipo Packs, 2.2 Jordans, Moab XL's and etc, etc..........
Old 10-23-2007, 06:55 PM   #110
Default the new paint (flames ) and some crawlin
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
nos482 is offline   Reply With Quote
Old 11-10-2007, 06:33 PM   #111
CRAWL_BOY is offline   Reply With Quote
Old 12-17-2007, 04:45 AM   #112
Default Rig pics
Heres my Scorpion Ax 10
brushed integy 55 T
Futaba 6EX stick pack
Futaba servos front and rear
Custom links bent rear and steering
Lip cut off protections Novak
Lipo battery
Losi Rock crawlsName:  Trailer 7.jpg
How about that truck and crawling area?!?!
crawlbe4youwalk is offline   Reply With Quote
Old 12-30-2007, 03:55 PM   #113
Truck Base : Steel tubing?
ESC: Mamba Maxx
Motor(s): integy 75t
Servo(s): JR 8711
Trans: R2D MG 995 shift servo
Axles: High lift
Tires: Soft Rock Crusher X/T 2.2
WB: 12 1/4"
Overall Width: 10"
Diff clearance: 1 7/8"
Center Chassis clearance: 2 7/8"
Overall height: 8 1/4"
hitman46mod is offline   Reply With Quote
Old 12-30-2007, 04:03 PM   #114
Truck Base : Steel tube
ESC: Proboat Water proof esc
Motor(s): Integy 75 T
Servo(s): MG 995 Waterproofed
Trans:Wheely King
Axles: Wheely King
Tires: Proline Moabs
WB: 12 1/4"
Overall Width: 10"
Diff clearance: 1 5/8"
Center Chassis clearance: 3 1/8"
Overall height: 10"
Old 01-01-2008, 08:02 AM   #115
Fatdog
Moab M3
Axial Trans
Black Revolver
Mamba Max
CC BEC
My Bent Links
Ummmm.............Basically what everyone else runs except for the front windonw that is to keep everything dry during the winter.
Chaotic Crawlers is offline   Reply With Quote
Old 01-05-2008, 01:46 AM   #116
Truck Base : Wheely King
ESC: JOLT-R reversible ESC (standard esc)
Motor(s): Saturn 27T
Servo(s): HPI SF-1
Trans:Wheely King
Axles: Wheely King
Tires: standard, every 2nd lug cut off rear tyres
WB: 10"
Overall Width: 11 3/4"
Diff clearance: 1 1/2"
Center Chassis clearance: 2"
Overall height: 11" incl. roof lights
Devience is offline   Reply With Quote
Old 01-15-2008, 03:27 PM   #117
My Fiances Pink Nylint Jeep and my AX10 (dovetailed along with crap paint job, I hate lexan...)
SStone is offline   Reply With Quote
Old 02-14-2008, 10:58 AM   #118
Default What's Going On Here???
My 6 year old drove the AX-10 right up onto the Bender. This was a great photo op. Nothing staged here. What will the little ones look like?
krikir is offline   Reply With Quote
Old 02-14-2008, 11:30 AM   #119
Talking
completly stock nylint 1/18th exept for tires,rims,stickers, and rock sliders
geekfreek95 is offline   Reply With Quote
Old 02-19-2008, 05:37 PM   #120
Truck Base : Tamiya TLT Rockbuster
TX: tq3
RX: tq3 mounted on the rear upper links
lexan antenna mount
ESC: Novak Rooster dielectrical grease and mounted on the rear upper link servo mount
Batteries: Sanyo 6 cell 3300 pack
Servo: Hitec 645mg with dielectric grease and plasti dipped mounted on a bender customs upper link servo mount
Trans: Stampede locked bearings grease no slipper
shocks
durtrax rear blue anodized with white losi springs
with 10 35 40 shock oil weights
Axles: Tlt cases rcp ring and pinion shimmed bearings stock shafts tg 10 axle shafts
custom spacers
drive shafts & yokes stampede custom drive shafts 2 males and one female with foam to space it out and stampede metal yokes
Tires: 2.2 moabs that have been softened up with a special recipe
star cut foam
wheel weights
Wheels: HPI racing wheels double narrowed
WB: 12.5
Overall Weight: 5.72 lbs
iwantoffroad is offline   Reply With Quote
Members' Rides - No talking - Similar Threads
What the #$%#$#@ are ya talking about? Paul58 Newbie General 10 01-13-2013 04:40 PM
Anybody know what im talking about?! shadowrejects Chit Chat 2 05-14-2010 06:26 AM
members 1.1 rides? SaVaGe MaN SS Chit Chat 4 03-28-2008 02:48 PM
