02-03-2016, 04:02 AM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Titanium lower links
For 2.2 crawlers - lower links; 1. What diameter are folks using? 2. I can only find rod not tube . With rod I could cut the thread direct on it. 3. Only found grade 5 so far in the uk - any good? Thanks |
02-03-2016, 07:14 AM | #2 |
| Re: Titanium lower links
Well, done a bit of searching!.. Looks like most common is 3/16 or 1/4" so 5 or 6mm... And yes all in rod not hollow tube it looks. Think I'll get some 4 and 5mm and see how it goes :-)... Also grade 5 is tough as hell! Apparently grade 2 is a lot softer and prone to bending with heavy abuse.... If anyone has any other info I'd be pleased to hear it :-). Cheers |
02-08-2016, 09:47 AM | #3 |
SSD RC has some nice ti tube links in different lengths with 6mm OD, and they make quality parts. You could always trim them down and re-tap if you need shorter, but they have different lengths. Home |
02-09-2016, 04:41 AM | #4 | |
| Re: Titanium lower links Quote:
Just rather build my own (& Cheaper) | |
