Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Removing twin retaning posts on hubs (bearings)
Old 01-08-2007, 11:39 AM   #1
Default Removing twin retaning posts on hubs (bearings)
I've searched and only found that they are 'pressed' in. I'm curious how people are removing these with out destroying the OEM hubs. I fitted all 3 of my projects with the front hubs, but can't for the life of me figure out how to get these two pins out to get the actual hub bearings removed.
I've tried beating them, using channel locks to 'press' them out and no luck.
Thanks for any assistance.
~P
Yes i searched, so keep your snide comments to yourself.
coreyperez is offline   Reply With Quote
Old 01-08-2007, 11:47 AM   #2
what do you mean you fitted them with front hubs??
i have never tried to remove mine, let me go find my spare hubs and see if i can figure it out
DougGass87 is offline   Reply With Quote
Old 01-08-2007, 02:58 PM   #3
I purchased the front hubs for my truck but noticed that there are two pins that hold the bearings into the hub. i just can't get these two pins out. They sorta resemble a jail cell (bars up and down) and won't allow the bearings to come out the back side of the hubs...
Kind of annoying... I don't want to destroy them, i have a friend w/a truck and wouldn't mind giving them to him if he needs them or selling mine for a quick .25....
~P
Old 01-08-2007, 03:04 PM   #4
aluminum hubs?
Old 01-09-2007, 09:14 AM   #5
I'm trying to get the bearings out of the plastic hubs to insert into the new alum hubs. Yes. Its just being a turd.... :-(
~P
Old 01-09-2007, 09:50 AM   #6
if you bought aluminum hubs why are you worried about messing up the plastic ones?
just cut off the face of them
Old 01-09-2007, 02:45 PM   #7
Well like i said, i don't want to destroy them. it really doesn't matter if i want to see if i can pee through them from across the room...
i don't see any reason to destroy a perfectly good part just because its being upgraded... But thats common sense talking there....
Old 01-14-2007, 06:50 PM   #8
Originally Posted by coreyperez
...it really doesn't matter if i want to see if i can pee through them from across the room...
What?
Gizmo is offline   Reply With Quote
