03-01-2016, 08:54 PM | #1 |
Rock Stacker Join Date: Sep 2013 Location: San Diego
| King Shocks
I am having some trouble with getting the air bubbles out. When I think I have finally got them all out I cap it and cycle them a bit at a slow and then faster pace. I have read multiple threads on here about bleeding out the air. Has anyone else had problems with king. Just trying to figure out if it's the shocks or just me. It's getting to become a thorn in my side as I have four shocks to do but can't get these Damon bubbles out My process is as follows, fill 1/4-1/2 way with oil. Move piston up and down until air bubbles are out. Fill to required amount and double check for bubbles. Cap and cycle. Thanks for any tips in advance. |
03-02-2016, 01:23 PM | #2 | |
| Re: King Shocks Quote:
King Off-Road Scale Dual Spring Shocks (90mm) | |
03-03-2016, 11:43 AM | #3 | |
03-03-2016, 08:31 PM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: King Shocks
As Natedog says, there will invariably be a little bit of air in the shocks because they are bladderless, but that won't affect performance. Just get the big bubbles out, fill almost to the top with the shaft fully compressed, and put the cap on. Once the cap is screwed all the way on, test the shock to make sure it compresses fully without springs. If not, take out a drop or two of oil and try it again.
03-09-2016, 12:31 PM | #5 |
Newbie Join Date: Jan 2016 Location: NorCal
| Re: King Shocks
Tuning shocks is a pain in the ass. I am a rookie and just started with this hobbie and i spent a good 3-4 hrs just trying to fine tune my ebay shocks. One or the other kept on not compressing to the same height but after trying and trying i finally got it work. you just have to go slow and not be so OCD about the air bubbles. just have to make sure that your shocks are compressing to the same lvl and has the same rebound.
03-28-2016, 08:31 PM | #6 |
| Re: King Shocks
If anyone else has these shocks then a PM to me on how you deal with these shocks would be great. I filled the shocks with oil two days ago and let the bubbles come out by letting them sit per the advice of an employee at my LHS. There wasn't a single bubble. After capping and cycling the shock a couple times I uncapped and to no surprise filled with bubbles. I am not sure why this keeps happening. I am getting to the point where I think it's time to upgrade the shocks. I know everyone has told me not to stress about a couple bubbles but I don't think couple bubbles should in to an entire shock body filled completely with bubbles. |
03-28-2016, 08:43 PM | #7 | |
These shocks (as well as any bladderless shocks) are supposed to have bubbles in them. If you don't feel the shaft skipping or jumping as you compress it, you're fine. If you feel skipping as it compresses, you probably need to add a bit of oil. When I set these up, usually end up filling each shock just over the level of the piston when the shock is fully compressed. At that level, once everything is sealed up, the shock has no problem reaching full extension and compression. That also ensures enough oil that the piston is not traveling through air pockets without oil resistance. | |
03-28-2016, 10:38 PM | #8 |
Quarry Creeper Join Date: Nov 2010 Location: Queen Creek, AZ
| Re: King Shocks
I filled mine to the bottom of the threads with oil, raised the piston, screwerd the cap on, wiped off any oil that got on the exterior of the body. This isnt rocket science. |
03-29-2016, 06:12 AM | #9 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
| Re: King Shocks
After watching the oil leak out of mine multiple times, because they suck at holding any oil, I turned to some marine grease just to lube the piston, and they work damn near perfectly for me.
03-29-2016, 06:28 AM | #10 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: King Shocks
I rebuilt mine when I bought them with green slime and haven't a leak yet. Fingers crossed they stay that way for a while. They still don't perform the greatest but as long as they don't leak I'm pretty happy. |
03-29-2016, 08:45 PM | #11 |
| Re: King Shocks
I will have to give that marine grease a try. That was another thing I noticed. But all is good for the time being.
03-29-2016, 09:32 PM | #12 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: King Shocks
I'll expand on what new2rocks said. Start with general rule number 1, air can be compressed but shock oil cannot. You can fill a shock with oil and no air inside the shock body but this creates a problem when you try and push on the shock shaft. As the shock shaft moves into the body of the shock it needs to displace oil. Since shock oil cannot be compressed it will be forced out either the seals or through the threaded cap. A shock needs air inside the shock body to allow room for the shock shaft. With an emulsion shock the air and oil mixes together but a diaphragm shock keeps the air and oil separate.
03-29-2016, 10:59 PM | #13 |
| Re: King Shocks
What Spookyseven said and I find emulsion shocks to be easier to assemble/bleed and are more durable and consistent for me.
King Shocks - Similar Threads | ||||
G-Made Piggyback shocks vs. RC4WD King shocks | crwlnCreeper | Axial Wraith | 33 | 01-20-2016 09:48 AM |
