Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: liquid mask
Old 01-09-2007, 06:26 PM   #1
Question liquid mask
how much liquid mask(oz.) would i need if i wanted to maks off all but 2 stripes on my body? where is the best place to buy liquid mask? thanks
Nub-4-life is offline   Reply With Quote
Old 01-09-2007, 06:40 PM   #2
Why dont you just mast off those two stripes and paint hte rest then remove the masking material and then paint those? Any hobby shop or Tower sells it.
Gula is offline   Reply With Quote
Old 01-09-2007, 07:01 PM   #3
I'm a stupid C U N T!
slobin3d's Avatar
or use tape and an exacto??
slobin3d is offline   Reply With Quote
Old 01-09-2007, 07:06 PM   #4
Liquid mask smells like a$$ no really blind folded you wouldn't be able to tell the difference.
Cole82 is offline   Reply With Quote
Old 01-09-2007, 07:08 PM   #5
im doing whit and green stripe and ive been told that the green will show thru the white thats why.
Old 01-09-2007, 07:45 PM   #6
You'll want to paint the green first just mask off around the strips. It's simple. really.
I would only suggest liquid mask if you are doing something really elaberate.
I've never used it and i've done some nice things as I didn't see a reason to buy it.... YET
Double J is offline   Reply With Quote
Old 01-09-2007, 07:49 PM   #7
Gold Star Baby!
You can also use the clear plastidip that comes in an aerosol can. Always paint the darker color first.
NorCal 2500HD is offline   Reply With Quote
Old 01-09-2007, 10:55 PM   #8
I have used the liquid mask before. It was a long time ago, one of the first bodies I ever painted. It really is a pain to use. For striping tape is sooo much easier. Plus, with tape you will get very straight lines (I found it difficult to cut the liquid stuff straight I am too shaky).
rash
rash_powder is offline   Reply With Quote
Old 01-09-2007, 11:09 PM   #9
slobin3d's Avatar
ive been trying to use liquid mask on my latest paint job, Ive been using faskolor (water based) and it softens the liquid mask and bonds it with the paint and when i try to remove it, it takes the paint off with it.
Old 01-09-2007, 11:36 PM   #10
crcoppens's Avatar
I have been using the fasmask lately and have had great results. The only problem as mentioned above is you can't be too shaky when cutting.
crcoppens is offline   Reply With Quote
Old 01-10-2007, 01:33 AM   #11
goingvertical's Avatar
i get the smallest bottle,and apply 2 coats with a 1" paint brush then using my wife's hairdryer between coats to help with drying time. using a red fine tip pen i draw what i want on the overspray film that's on the body then use a sharp exacto to cut out my design on the inside.hope this make's sense.
goingvertical is offline   Reply With Quote
Old 01-10-2007, 05:09 AM   #12
S-Dog's Avatar
use the bob dively liqquid mask.... it has almost no smell
S-Dog is offline   Reply With Quote
Old 01-10-2007, 10:46 AM   #13
Thats what I used on all my bodied. Never had an issue. But with doing what you want. Just use tape. That way you get perfect lines...
Old 01-14-2007, 03:56 PM   #14
Question
thanks. based on what i heard i think ill just roll with tape. but 1 question.. A. whats the best kinda tape to use. B.will it lead adhesive resido?
Old 01-14-2007, 07:45 PM   #15
the blue one..go to like home depot and get the blue one..its best...no it doesnt leave residue..very easy to take off too...
jrdk92 is offline   Reply With Quote
Old 01-15-2007, 11:56 AM   #16
With the blue painters tape you have to be really careful! The lack of "sticky residue" can lead to the masking lines bleeding. Make sure that you rub down all the edges and get a good seal before you paint!
phishead1101 is offline   Reply With Quote
Old 01-15-2007, 12:01 PM   #17
heres what ive used in the past, ive found the bob dively (sp) liquid mask to be the best and as far as tape i like the 3m green automotive masking tape, i find it at any place that sells paint supplies. also try the fineline tape from 3m for thinner lines, its more of a plastic tape and works great for 1/8-1/4 inch lines.
lostwages is offline   Reply With Quote
Old 01-15-2007, 12:12 PM   #18
Cool ty
thanks i just went with electrical tape amazingly it works like a charm i used an x-acto to curve the ends. i decided to do black and white stripe. i dont have the white yet but the black looks sick! thanx 4 all the help every one
Old 01-15-2007, 12:25 PM   #19
You can also paint the white first, when its dry, go over it with silver, it won't darken the white, but makes it opaque enough that the green won't show through
mspohn is offline   Reply With Quote
Old 01-15-2007, 12:45 PM   #20
I'm Dracula, Bitch.
JeremyH's Avatar
That is an understatement. My wife says it smells like a cross between mac-n-cheese and vomit.
JeremyH is offline   Reply With Quote
