03-18-2016, 06:14 AM | #1 |
Newbie Join Date: Nov 2015
| Do i need one or two??
Hey guys was hoping someone could help me. So I have a scx10 with a high torque savox steering servo which draws quite a bit. So I have a glitch buster plugged into my third channel which does help a little. What I want to do is to add a servo to act as a winch on my 3rd channel and was going to use heyok 2 position to 3 position adapter. With all that being said I was going to drop the glitch buster and go with an external bec. Do I need to have two; one for the winch and one for my servo or will one be enough? Thanks any thoughts or opinions would help. Sent from my SM-G903W using Tapatalk |
03-18-2016, 08:07 AM | #2 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: Do i need one or two??
I never had a problem with running two with one. You could also run the steering servo off an ex bec and the winch from the rx off the esc bec.
03-19-2016, 04:20 PM | #3 | |
| Re: Do i need one or two?? Quote:
Have you considered this controller? Winch Controller for Radio with 2 Position Third Channel Or, I could make a relay version of it if you prefer. If you aren't running some sort of external BEC to ensure you have good power to your steering, I suggest you give it a try. It will probably cure your need for the glitch buster. There are many options for running an external BEC. This thread describes two versions that I make: No Brainer BEC This might be worth a look too: Yes, another one: BEC to HV Servo Wiring | |
03-21-2016, 08:12 AM | #4 |
Thanks heyok I was actually talking to my lhs on ordering one of your 2 position to 3 position on third channel. But found out I have a ttx300 that u can actually program I didn't know. (Manuals didn't come with my rc I assume when I ordered it it was floor model and just got tossed in the box and shipped. But I think I will get an external bec was thinking cc bec but don't want to purchase the link. Was wondering if I could get on that outputs 6v. Sent from my SM-G903W using Tapatalk |
03-21-2016, 09:05 AM | #5 |
Welcome. I think the CCBEC is set to 5.5 volts from the factory - someone correct me if I am wrong. You can of course change it using a programmer. If you get the No Brainer BEC I can preset it to whatever voltage you ask - as long as it is about two volts lower than your pack voltage. |
