05-16-2016, 09:33 AM | #1 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Ssd d60 housing
So I was crawling today and all of sudden the steering stopped, the truss had come off (I'm running axle mount servo) and the threads and pulled out of the housing. Is there any to fix this or do I buy a f9 housing? 1.9 Ibex tuber |
05-16-2016, 10:50 AM | #2 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Ssd d60 housing
few years back when i bought a set of fancy alloy axle cases machined by cnc fairies i was super stoked. when i got them i was amazed at the detail and the quality. so happy. when i put them together... they wouldnt spin. i tried to contact the fairies to exchange the problem part with one that wasnt a problem, since its the fairies job to make parts i figured it was an easy solution. somehow... the fairies were able to take my money over the magical interwebs but 3 times werent able to reply to my polite requests to exchange a p.o.s. part for one that i didnt have to sand pinion bearings down to get to work. fairies never made good never got back to me. SO... i ended up sending my fancy fairy axles to a troll who fixed them for me. i would just get a few spare ssd axle cases and spend the rest on other stuff. maybe not torque down as hard on the truss screws. or maybe beef tubes can be tapped or are tapped to tie the truss mount to the tubes. Last edited by badhoopty; 05-16-2016 at 10:59 AM. |
05-16-2016, 11:56 AM | #3 | |
| Re: Ssd d60 housing Quote:
Ok thanks, now what about the f9s?? Will the f9 last me longer? | |
05-16-2016, 01:30 PM | #4 | |
there are cheaper options that might let you put some of that money in other places. i really like the team ottsix tko housings, and beeftubes makes a pretty sweet setup for them. team-ottsix-racing BEEF TUBES | |
05-16-2016, 01:34 PM | #5 | |
Awesome thanks man! I will look into that | |
05-16-2016, 04:11 PM | #6 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: Ssd d60 housing
Would brass inserts work in the axle tubes? Also for the screw that holds the truss to the diff I wonder if you could use a longer screw and a nut inside the diff, although you would need to use locktite or something to keep it from coming loose. Stripped screws are annoying but I wouldn't throw away a housing just for this reason.
05-16-2016, 06:51 PM | #7 | |
I'm thinking about making beef tubes (I'm cheap to buy ones) and drill and tap them. What's the threads on the screws? | |
05-16-2016, 08:17 PM | #8 |
| Re: Ssd d60 housing
Silly question, did you have all three screws in the truss?
05-17-2016, 02:32 AM | #9 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: Ssd d60 housing Everytime somebody has had a problem it has been because they have not fitted the the middle flat head screw in the truss. It makes a huge difference. SSD D60s have proven to be very strong if assembled correctly. |
05-17-2016, 08:09 AM | #10 |
| Re: Ssd d60 housing
Throw some Heli coil inserts in them. Stronger than when new! I can do this for you if needed. PM me. |
05-17-2016, 08:38 AM | #11 |
Pebble Pounder Join Date: Mar 2014 Location: Raleigh
| Re: Ssd d60 housing
You can also do the old trick of using thick CA and putting a screw in (no truss installed). The glue will cure and you can unscrew the screw and put it all back together. Not perfect, but will hold up quite a while. I had a Wraith with this fix for the C-hubs because I was too cheap and stubborn to replace them. Ran about a year like that.
05-17-2016, 01:18 PM | #12 |
| Re: Ssd d60 housing |
Ssd d60 housing - Similar Threads | ||||
Offset SSD D60 axle | ctrwannabe | General Crawlers | 18 | 04-07-2016 08:58 PM |
Any had this problem with the ssd d60 housing? | Bmxreeves | Axial SCX-10 | 0 | 01-09-2016 04:13 PM |
