Thread: Inexpensive build your own 1/10 truck
Old 09-01-2016, 07:11 PM   #21
Default Re: Inexpensive build your own 1/10 truck
Originally Posted by moondaddy View Post
Before you build it, get an aluminum steering kit
Do you have a link or a part number?
b4tn is offline   Reply With Quote
Old 09-05-2016, 12:28 AM   #22
He loved it! Thanks all. Now the build begins!
Old 09-07-2016, 05:17 AM   #23
The first thing you need to upgrade asap are the tires
It you do a suspension lift please share pics and details
aiden102408 is offline   Reply With Quote
Old 09-07-2016, 05:45 AM   #24
Funny you say that, I was looking into tires last night. The tires that it come with are hard as a rock, look small on the truck, and are less than aggressive. I am still doing my homework but I am looking into a 1.9 rim and tire with a 4" diameter. I am considering a bit of an offset as well to give it a slightly wider stance.
Old 09-07-2016, 06:18 AM   #25
I put beadlocks on mine last night
I need to hack the body a little as they rub
Old 09-07-2016, 07:01 AM   #26
What tires are these? Thats exactly the look we are going for.
Old 09-07-2016, 07:03 AM   #27
I'm not sure of the model of the tire .
I can get that info in a little while for you
Old 09-07-2016, 07:31 AM   #28
The beadlocks looks like boomracing beadlocks.
sent by magic_yeti
magic_yeti is offline   Reply With Quote
Old 09-07-2016, 07:49 AM   #29
Moderator
JatoTheRipper's Avatar
Those tires look like cheap tires from eBay. If that's the case, they aren't going to provide the best grip. You should get tires from a reputable manufacturer for good grip - Pitbull, ProLine, or RC4WD (make sure they're the X2SS compound not X3).
Old 09-07-2016, 12:00 PM   #30
For the steering kit i just got one from gpm, not sure if there is a better or worse option there. For the tires (on my landfreeder anyways) you won't want to go much bigger than 96-98mm. Anything taller than that will rub the tub/catch on the body during flex
moondaddy is offline   Reply With Quote
Old 09-07-2016, 04:42 PM   #31
The tires on mine are rubbing bad
I need to trim the body
Old 09-12-2016, 08:27 PM   #32
Default Inexpensive build your own 1/10 truck
The RC4WD 1.9 Rock creepers came today. My son bought them with his own money. I'm having a real hard time not ordering him a sidewinder, lipo, and a crawler motor
Old 09-20-2016, 06:43 PM   #33
Gonna have to lift the body.
Old 09-20-2016, 06:49 PM   #34
snapon boy's Avatar
Ae2 and a tekin 55t brushed motor and your set up and cheep.
149 r/c worx team driver
snapon boy is offline   Reply With Quote
Old 09-20-2016, 06:58 PM   #35
Sticking with stock for now. But if we do upgrade I will probably go with the 55t motor and a sidewinder. That's what I run in my ScX10 with 3s Lipo and have been very pleased for truck that we just bash around with.
Old 09-25-2016, 09:36 AM   #36
I have to be honest. I am a little blown away by this little truck. We built it together with my son doing the majority of the work. We had a few issues at first but all the bugs have been worked out with a little bit of locktight. It's way to fast for my taste with a standard Nimh but despite my offer to gear it down he likes that it blows my geared down 3S lipo SCX 10 away in a drag race. What's bad is now I kind of want to build one now taking time with details making a scale replica.
My 1:1 toy.
Old 09-26-2016, 05:17 PM   #37
Using Blackfoot's build thread I trimmed the C's for more front end droop and locked the front diff. My son built the rear diff and didn't think to do the locked option. We took it all apart tonight and locked the rear. We also cut the front brick off. Worlds of difference over our back yard stream bed rocks. Next up is an upgrade to the rear links and steering.
Old 09-27-2016, 08:02 AM   #38
Moderator
I'm not sure why you'd go with the Sidewinder unless you want the adjustability of the drag brake. The HobbyWing WP1060 is a great, $20, waterproof, brushed ESC. The drag brake is a little stiff, but for a newbie that's not a bad thing.
Old 09-27-2016, 07:37 PM   #39
The ability to program it. That and I already have the programmer and am familiar with the software. I am going to cut full throttle and add a drag brake and crawler brake.
Old 11-06-2016, 12:16 AM   #40
sss
I know it's easy to order online, but why don't people support the local hobby shop anymore
Sent from my HTC6535LVW using Tapatalk
sss is offline   Reply With Quote
Inexpensive build your own 1/10 truck - Similar Threads
LOOKIE HERE!!! (Good inexpensive 2.2 parts truck or basher truck...) STEEL_CITY_CRAWLER Chit Chat 0 08-24-2007 12:44 PM
Truck build-up...with no truck! bugman72 Comments, Suggestions, and Help 17 07-27-2006 10:23 AM
