10-14-2016, 04:19 PM | #1 |
Pebble Pounder Join Date: Oct 2012 Location: Harleysville
| MOA overdrive question.
Hoping to get a question answered for me. I have a bully 2 with the HH dual minis controlled by a spektrum dx6r. I have the rear esc plugged into the thr plug and the front esc plugged inti the aux. I've alwayd heard on a moa that you should have the front axle should be overdriven. Thinking this i have it set at 53% front and 47% rear but is there a certain science on how much to overdrive or is it just by feel on the rocks? |
10-14-2016, 04:21 PM | #2 |
| Re: MOA overdrive question.
Feel and your eyeballs.
10-14-2016, 04:33 PM | #3 |
Watch your length.... the rear will "drag" and stretch your wb out Sent from my iPhone using Tapatalk |
10-14-2016, 05:48 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Re: MOA overdrive question. |
10-14-2016, 07:24 PM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
There isn't one answer so thats why you haven't found the perfect answer. It all comes down to what your climbing. Some stuff requires different over/under drive. The more you drive, the more you will learn how to use it to your advantage. Run it 50/50% then as your climbing and your rig wants to flip back, you'll want to add more over drive so front tires pull you up something. Practice, practice and more practice.
10-14-2016, 10:09 PM | #6 | |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: MOA overdrive question. Quote:
I actually have mine set at a 4% differential, but use a different radio. | |
10-14-2016, 10:31 PM | #7 | |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Negative If you are worried about the wheelbase you need to flex the car to find the longest point and that should not extend past 12.5" OP, learn how your car drives. With a decent set up you will find 50/50 handles the best in most situations. Overdrive on the front helps in steep climbs, but most times in my time I used 50/50 or dig. Rarely at all did I overdrive the front. | |
10-15-2016, 06:25 AM | #8 |
I'm lost then, when mine is underdriven it extends to max wheelbase..... Sent from my iPhone using Tapatalk |
10-15-2016, 07:40 AM | #9 |
| Re: MOA overdrive question. One great thing about MOA is the ability to change your overdrive on the fly. You aren't restricted to a single ratio like you are with a shaftie, so don't limit yourself by thinking there is a "perfect" ratio. It changes with your terrain and driving style. This does depend on what your radio is set up to do though. |
10-15-2016, 09:43 AM | #10 | |
I do agree that 50/50 is best for most situations. | |
10-15-2016, 02:57 PM | #11 |
| Re: MOA overdrive question. This spektrum uses the 50/50 ratio but they both get 100% power. Thanks
10-17-2016, 02:11 PM | #12 |
Thanks for all the help. I've decided to leave it at 50/50 and added a trimmer switch that will automatically adjust the overdrive without having to go in and program it.
MOA overdrive question. - Similar Threads | ||||
Overdrive mod question. | philg | Losi Mini-Rock Crawler | 8 | 11-08-2012 02:19 PM |
Traxxas overdrive question | mmatthews | Losi Mini-Rock Crawler | 30 | 11-14-2011 11:49 AM |
Overdrive gearing question | jeepster73 | Axial Wraith | 1 | 07-15-2011 04:29 PM |
overdrive question | tim the toolman | Losi Mini-Rock Crawler | 17 | 07-09-2011 06:41 AM |
