01-16-2017, 04:13 AM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Wind Gap
| Yeti transmission
I have a quick question, is there a way to swap out the output dog bone cup on yeti transmission for a standard output that will accept a driveshaft? Sent from my SM-N920V using Tapatalk |
01-16-2017, 07:46 AM | #2 |
| Yeti transmission
I run a MIP rearshaft, not sure what you need, are you talking about the front shaft ?? I think that's my only stock part left that hasn't failed Hang up and Drive |
01-16-2017, 11:17 AM | #3 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
| Re: Yeti transmission
the cup running to the front diff from the transfer case is attached with a setscrew, remove the setscrew and the cup comes off and should accept a driveshaft same as the rear ouput. Another option would be to use the transfer case setup from a bomber which extends the length of that output quite a bit.
Yeti transmission - Similar Threads | ||||
Yeti transmission | Synister_Intent | Axial SCX-10 | 2 | 10-05-2016 09:04 AM |
Yeti transmission | Synister_Intent | Axial SCX10 II | 0 | 10-04-2016 04:52 AM |
Yeti Transmission Bearing?? | byrnieman | Axial Yeti | 4 | 07-06-2016 12:13 PM |
Yeti XL 2 Speed Transmission | deployedcivy | Axial Yeti XL | 5 | 12-30-2015 07:17 AM |
Yeti Transmission in SCX | Di_Spencer | Axial SCX-10 | 5 | 09-20-2015 09:11 PM |
