2 speed trans issues I have a Wraith with an SSD 2 speed & a Yeti with a 2 speed kit installed. Both have Traxxas waterproof servos with Kimbro servo savers for shifting. I use a Futaba 4PLS radio and for some reason, I seem to have problems with the end points never being right. They seem to change and need adjustment alot. Is there some set up procedure I'm missing? Is this common. Thanks |
2 speed trans issues I have a yeti and the two speed.... I noticed the EP were tight with my 4PLS 59 and 31.... I wasn't so worried about the center, just didn't want overshift causing servo hanging Make sure your servo saver is tight, watch it when shifting Hang up and Drive |
Re: 2 speed trans issues Why use servo savers? I don,t think I would use them. |
Re: 2 speed trans issues It's shifting not steering. A bit of slop won't be noticed and prevents overshifting Hang up and Drive |
