Thread: Centered plastic housing.
Old 03-19-2017, 06:09 PM   #1
Default Centered plastic housing.
Hello all.
I'm looking for a centered plastic housing for a custom build with a 9.75" or 10" width.
I'm not set on any brand, so shoot what you would think would be best! Although I would rather have a good looking housing than not.
Cheers Jacob.
Bmxreeves is offline   Reply With Quote
Old 03-20-2017, 06:12 AM   #2
binaryterror's Avatar
Default Re: Centered plastic housing.
SSD Dana 60's that use the SCX10 axles is both centered and very scale looking.
binaryterror is offline   Reply With Quote
Old 03-20-2017, 07:35 PM   #3
Do you know the hex to hex width of the ssd axles? I'm looking for 9.5"-10"
Even though I've been in the game for a while, I'm still a newb.
Old 03-21-2017, 05:56 AM   #4
I don't, but its the exact same as all SCX10 axles. It's only a housing change for the SCX10 basically.
Old 03-21-2017, 06:52 AM   #5
Moderator
JatoTheRipper's Avatar
The SCX10 axle is narrow and not going to get him anywhere close to 9.5" to 10". The SCX10 axle is only 192mm / 7.56" wide.
The Wraith axle, according to information on this site, is around 9.5" wide. I know it's not a centered housing though.
The MST CFX-W axle will get you close if you don't mind portals. They aren't cheap though.
http://www.ebay.com/itm/MST-MPA-Axle...0AAOSwUKxYeEis
Old 03-21-2017, 07:09 AM   #6
If it's wraith width. How about SSD Diamond centered axle. Have the SSD wide Diamond in my Yeti, very happy with it.
But it's made of alloy
sent by magic_yeti
magic_yeti is offline   Reply With Quote
Old 03-21-2017, 07:12 AM   #7
I had Carter Fab build me a centered wraith housing about 5 years ago. Not sure if he still does it or not but I'd give it a shot.
DrewHammer is offline   Reply With Quote
Old 03-21-2017, 08:47 AM   #8
Ok cool thanks! I'll look into that for sure!
I found that as well and I don't like the portal idea (btw looking for a rear)
sent by magic_yeti
I'd love to do that, but at this time I can't afford something like that. Thanks though!
Old 03-21-2017, 04:31 PM   #9
SSD
Just wait a couple of weeks ;)
SSD is offline   Reply With Quote
Old 03-21-2017, 05:01 PM   #10
That's always a good sign !
BigSki is offline   Reply With Quote
Old 03-21-2017, 05:02 PM   #11
Yes it is, lets hope it gets s in the next couple weeks!
Old 03-29-2017, 10:59 AM   #12
4RunnerKid's Avatar
SNEAK PEEK - New SSD HD D60 Centered Rear Axle!
4RunnerKid is offline   Reply With Quote
Old 03-29-2017, 11:07 AM   #13
Originally Posted by 4RunnerKid View Post
Thanks dude!
Old 03-29-2017, 03:14 PM   #14
Moderator
Can we get a front, centered axle?
Old 03-29-2017, 06:07 PM   #15
Now, if anything can be added to the wish list- an offset front diffy with the same overall track width would be nice ! I know that the Axial AR60 is already offset, it just doesn't look as nice as the pumpkin design of the SSD axles.
Old 03-29-2017, 06:57 PM   #16
This changes everything... I'm picking up a Wraith chassis and was planning on a 1.9 build with SCX axles but this will be cheaper and may change my mind.
struhall is offline   Reply With Quote
Old 03-30-2017, 03:48 AM   #17
SSD
Yes that would be nice wouldn't it ;)
These axles have big pinion bearings and have thicker tube walls than stock too. So it's not just a cosmetic upgrade.
Old 03-30-2017, 05:21 AM   #18
What's the weight compared to stock? Will beef tubes fit?
calcagno45 is offline   Reply With Quote
Old 03-30-2017, 07:06 AM   #19
SSD
This is centered so beef tubes wont fit anyway. Also it is plastic so weight difference to stock is probably not significant.
Old 03-30-2017, 07:34 AM   #20
Moderator
Centered front housings to match the rear would be nicer!
Centered plastic housing. - Similar Threads
The plastic housing just got stronger Erik D_lux Axial Wraith 5 05-04-2016 08:15 PM
Centered F9 Front Housing? What do YOU think?? DirtyChevy45 General Crawlers 53 11-10-2015 02:18 PM
vanquish centered axle shafts to GCM centered housing compatibility npcaldwell Axial Yeti 7 01-31-2015 12:47 PM
