03-26-2017, 06:16 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Centerton
| XR Mod
So I want to build up the SCX10 axels with the xr mod. Does anyone know what VP universals I'd need. I think I have the right ones but I can't tell. Any help would be greatly appreciated. |
03-26-2017, 06:37 AM | #2 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: XR Mod
I do believe you use those, as they are equal length as the SCX is. I cut Ti axle shafts for the rear with this option and depending on lockouts, Wraith lockouts use 2 long side XR length shafts and with XR lockouts 2 short side XR shafts are used. But the front is different because it is centered from the beginning. Hope that makes since. |
03-26-2017, 06:42 AM | #3 | |
| Re: XR Mod Quote:
Yes it kind of does thank you! I'm gonna use scx10 lockouts out back just because I'm not gaining anything either way for the rear. | |
03-26-2017, 11:12 AM | #4 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Re: XR Mod |
03-26-2017, 11:17 AM | #5 | |
| Re: XR Mod Quote: Thanks but I'm doing this to scx axels | |
03-26-2017, 11:42 AM | #6 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
| Re: XR Mod |
03-26-2017, 11:59 AM | #7 |
Quarry Creeper Join Date: May 2016 Location: Nässjö
| Re: XR Mod
So if you are doing this mod you can use regular scx10 universals? Skickat från min iPhone med Tapatalk |
03-26-2017, 12:00 PM | #8 |
| Re: XR Mod |
03-26-2017, 12:09 PM | #9 |
| Re: XR Mod
If you have regular beef tubes but no splines can you use those? Will the hole in the regular beef tubes line up with wraith hubs? Skickat från min iPhone med Tapatalk |
03-26-2017, 12:11 PM | #10 |
| Re: XR Mod
regular tubes=scx10 hubs Splined tubes= Wraith hubs and universals. Sent from my iPhone using Tapatalk |
03-26-2017, 12:28 PM | #11 |
| Re: XR Mod
Gues you can use regular beef tubes if you have that. How to do the narrow XR10 mod to Axial axles Skickat från min iPhone med Tapatalk |
03-27-2017, 01:19 PM | #12 |
| Re: XR Mod |
03-27-2017, 01:55 PM | #13 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: XR Mod
I'm surprised nobody has mentioned this yet but...Vanquish VVDs really aren't the best for steering angle, and if you're doing the XR mod the advantage is that you gain a lot more of it. Just point that out unless it's been considered already.
03-27-2017, 04:05 PM | #14 |
| Re: XR Mod |
03-27-2017, 04:07 PM | #15 | |
| Re: XR Mod Quote:
Okay. What vvds should I get that'll be very strong and good steering angle? Sent from my iPhone using Tapatalk | |
03-27-2017, 04:54 PM | #16 | |
| Re: XR Mod Quote:
Also, Harley has 2 videos on this where he shows the process pretty well, depending on what tubes you go with, starting on vid 1: https://www.youtube.com/watch?v=gW-kPQZjYW8 | |
03-27-2017, 04:55 PM | #17 | |
| Re: XR Mod Quote:
I'm gonna use the xr mod narrow tubes for the front and regular beef tubes in the rear. How strong are the axial universals? Sent from my iPhone using Tapatalk | |
10-11-2017, 05:49 PM | #18 |
Newbie Join Date: Oct 2017 Location: Ammon
| Re: XR Mod
[QUOTE=scaler44;5688172]I'm gonna use the xr mod narrow tubes for the front and regular beef tubes in the rear. How strong are the axial universals? I have run 35-55t motors on 3s with the lowest possible gearing on 2.2 tires completely bound up and have never broke an axial universal. I am also going to really stress these puppies out once my new axle build is done. Super wide axles and big 2.2 tires even by 2.2 standards. |
10-29-2017, 12:05 PM | #19 |
Newbie Join Date: Aug 2016 Location: Miami
| Re: XR Mod
The axial universals are pretty damn strong if you don't lock them up. DLUX also sells FBA shafts which are strong as sh*t.
XR Mod - Similar Threads | ||||
I need your opinion about this fastcage mod or the normal mod | PSH72 | Axial Wraith | 21 | 10-09-2015 07:21 PM |
Xirtic + JP High Clearance Steering Mod on Mod | JeffK11 | RC4WD Bully | 1 | 02-01-2012 09:55 AM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
