04-06-2017, 05:59 PM | #1 |
Rock Stacker Join Date: Oct 2015 Location: Southern Oregon
| Axial Slipper Clutch Pad Question
Hello, Anyone try to make these? (part # AX3106 If so, what material did you use? Other than EBAY, I have not been able to find these to purchase and it appears to me that these could be made and glued onto the spur gear. The local hobby shop checked with Axial and the earliest these will be available is the end of May. I do not have enough experience as to how much a properly setup clutch will or should be allowed to slip, so I do not know what material might work. Any suggestions will be greatly appreciated. Thank you. |
04-06-2017, 06:01 PM | #2 |
| Re: Axial Slipper Clutch Pad Question
In a crawler, no slip. No point in a slipper at all.
04-06-2017, 09:04 PM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
I wonder how close in size the Duratrax slipper pads are, they are at least hex compared to everyone else's octagonal. TowerHobbies.com | Duratrax Slipper Pad Brushless Evader (4) Though I to am inclined to just lock the thing down tight anyway. |
04-07-2017, 06:59 AM | #4 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
if you HAVE to go slipper try this upgrade. best on the market. https://supershafty.com/collections/...eefy-top-shaft https://supershafty.com/collections/...eel-slipper56t |
04-07-2017, 09:48 AM | #5 | |
| Re: Axial Slipper Clutch Pad Question Quote:
Shaft should finally be available next week ! Hang up and Drive | |
04-07-2017, 01:17 PM | #6 |
Pebble Pounder Join Date: Mar 2016 Location: Mountains
| Re: Axial Slipper Clutch Pad Question |
04-07-2017, 02:46 PM | #7 |
I dunno. Keep the pads in place and crank the nut down.
04-07-2017, 02:53 PM | #8 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Self adhesive sand paper in place of the pads, tighten it down and it ill be locked solid.
04-08-2017, 05:32 AM | #9 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
04-08-2017, 06:31 AM | #10 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
I've just been pondering the use of slipper clutches/pads. My son stripped out the gears in his SCX10 gearbox. Spur has been fine. If you tighten down the slipper so it doesn't actually slip, you'll damage the gearbox gears which cost about $10AUD to replace If you losen the slipper you then torch the slipper pads which are like the same price to replace and are likely more fiddly to replace...plus you lose wheel torque. I'm currently thinking it's easier to replace plastic gears. If I can find some affordable steel gears I'll go steel and tighten the slipper down though only the Axials are available and they are about $85 a set plus postage! |
04-08-2017, 08:07 AM | #11 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
I have been using traxxas 32p gears and just cranking them down. Even with the slipper set to slip i still strip out the plastic gears eventually. After i upgraded to all steel gears the transmission is the last of my worries when i go out wheeling. I have both of my sons transmission's setup the same way and theirs have been trouble free as well.
04-08-2017, 11:52 AM | #12 |
04-09-2017, 11:28 PM | #13 | |
https://www.rpphobby.com/product_p/hotsscp1000t.htm TowerHobbies.com | Hot Racing Hardened Steel Gear Set AX10 Unfortunately the equally well priced SSD are OOS at most places but if your waiting on other bits as well https://www.rpphobby.com/product_p/ssd00172.htm https://www.amainhobbies.com/ssd-rc-...72/p585310?r=0 Other option is the Robinson middle & bottom gear | |
Axial Slipper Clutch Pad Question - Similar Threads | ||||
Slipper Clutch Question | jdhorton000 | Axial Yeti XL | 10 | 10-12-2015 10:22 AM |
Slipper Clutch Question? | mmatthews | Losi Mini-Rock Crawler | 5 | 08-03-2011 01:48 AM |
robinson slipper pad question | NeXt559 | Non Crawler RC's | 0 | 01-09-2010 09:53 AM |
