05-23-2017, 08:58 AM | #1 |
Pebble Pounder Join Date: Aug 2016 Location: N/A
| Mixing Axial spur/other pinion brands
Could you please post your experiences with using 32P Axial spur gears with different brand pinion gears? I seem to remember Traxxas pinions being quite noisy even though they are also sold as 32P. Thanks.
05-23-2017, 09:00 AM | #2 |
| Re: Mixing Axial spur/other pinion brands
No problems. Maybe you're thinking metric pinions? |
05-23-2017, 10:46 AM | #3 |
Thanks EeePee, but I'm pretty sure they were 32P Traxxas pinions. I'll try it again and see if I can re-create the noise. What concerned me was not the noise per-se, but that it was an indication of increased friction and wear.
05-23-2017, 06:23 PM | #4 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Mixing Axial spur/other pinion brands Quote:
Doesn't matter what brand, as long as it is 32p to 32p gears, it should not have any problems. | |
05-23-2017, 06:29 PM | #5 |
32p is 32p no matter who makes it, the 32p is very close to the metric mod 1.0 pinion. If the mod 1.0 pinion is run on a 32p gear... it will be noisey...
05-23-2017, 09:22 PM | #6 |
| Re: Mixing Axial spur/other pinion brands Ic. So do you know if Traxxas pinions are actually 32p, or Mod 1.0? Because I've seen them described as both.
05-23-2017, 10:02 PM | #7 |
all the traxxas pinions I have bought have worked with my 32p spur perfectly..
05-23-2017, 11:40 PM | #8 |
Mod 1 is visibly more coarse than 32p. I want to say that mod .8 is the one that's really close to 32p.
05-24-2017, 12:54 AM | #9 | |
RCC Addict Join Date: Jun 2004 Location: ORegon
I always use Robinson Racing pinion gears. Excellent quality! | |
05-24-2017, 11:55 AM | #10 |
| Re: Mixing Axial spur/other pinion brands Yes and still too noisy. I've used Traxxas 0.8 Mod spurs with 32 pinion (also Traxxas) on my Wraith (only gears available at the time to get the gearing I wanted) and it was too noisy. Always best to use same pitch gears together. |
05-24-2017, 12:39 PM | #11 | |
yup, my bad its mod .8, still noisey | |
05-24-2017, 12:58 PM | #12 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Mixing Axial spur/other pinion brands |
05-29-2017, 11:45 AM | #13 |
| Re: Mixing Axial spur/other pinion brands Yeah, an old trick I remember from 2wd offroad days is to spin up the tranny with toothpaste on the gears (we're talking plastic gear Stealths). I assume it would also work on spur gears but may be a little messy!
06-05-2017, 11:33 AM | #14 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
Yeah i have noticed traxxas pinions on axial spurs are noisy. If i recall i have used Robinson racing pinions with axial spurs with better results as far as quiet goes. Alot more expensive tho.
Mixing Axial spur/other pinion brands - Similar Threads | ||||
alternative brands for axial wraith parts? | Nemo | General Crawlers | 18 | 04-07-2014 12:14 PM |
80 Spur, 2S, Axial Stock 55T Motor.. what pinion? | StefanM | Axial AX-10 Scorpion | 8 | 11-05-2011 04:48 PM |
spur/pinion??? | armycrawler101st | Newbie General | 3 | 11-06-2010 05:22 PM |
pinion and spur for axial trans | JeepCrawler | Newbie General | 1 | 03-21-2008 02:03 PM |
