Like Tree19Likes
  • 3 Post By neilus
  • 2 Post By svt923
  • 4 Post By Locked Up
  • 2 Post By cmbscx10
  • 2 Post By Locked Up
  • 1 Post By neilus
  • 1 Post By BigSki
  • 2 Post By kmnss
  • 2 Post By The Violator
Thread: Slipper Eliminator kit for SCX10/AX10 Transmisson
Old 05-28-2017, 06:33 PM   #1
Default Slipper Eliminator kit for SCX10/AX10 Transmisson
I've been waiting for a while for lockeduprc to get their slipper eliminator kit back into stock. I'm now at the point in my build that i need it.
Does anyone else do a similar thing? I've got the original parts from the AX10 that i think i could use to do it, but ideally i'd like replace the plastic part that the spur gear screws to.
Thanks for any help.
neilus is offline   Reply With Quote
Old 05-31-2017, 02:54 AM   #2
Default Re: Slipper Eliminator kit for SCX10/AX10 Transmisson
Was always wanted to try out of one these Slipper Eliminator kit since last year, but they are always run out of stock. Ended up with Robinson Racing 32P Slipper Kit Steel Slipper(56T)( Ordered from SuperShafty ) and of cause happy with it.
Teng is offline   Reply With Quote
Old 05-31-2017, 04:19 AM   #3
Venom used to make an aluminum version of the plastic slipper eliminator from the AX10, I picked up one still in the package on eBay not too long ago.
Edit: There is one on ebay now: Venom VNR4017 Gear Adapter: Axial AX10
Use it with Axial top shaft AX30197
Natedog and Teng like this.
svt923 is offline   Reply With Quote
Old 05-31-2017, 08:00 AM   #4
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Sorry on the out of stock!
We had a batch of the top shafts but I was not happy with them.
So we are remaking them.
Should be back in stock soon.
Locked Up is offline   Reply With Quote
Old 05-31-2017, 06:05 PM   #5
cmbscx10's Avatar
Thanks for the info and great news. I have needed 2 for a bit, checked periodically and have the back In Stock alert. Had one in my SCX and wraith and work perfectly.
cmbscx10 is offline   Reply With Quote
Old 06-03-2017, 05:34 AM   #6
Do you have any of the spur adapters on their own in stock? I assume they would work with stock original AX10 shaft, which i have a few of?
Old 06-03-2017, 07:08 AM   #7
Locked Up's Avatar
I believe we do but they are not listed individually.
I'll get a separate listing in the store.
Natedog and Jeepiac like this.
Old 06-03-2017, 07:35 AM   #8
Lovely job. That'll get me sorted until the full kits are back in stock. Will it work ok with the AX10 shaft?
Natedog likes this.
Old 06-19-2017, 02:21 PM   #9
Just some guy
Any ETA on when the kits will be in stock? I assume you don't have the gear adapters in stock either as I don't see them in a separate listing in the store. Sorry if I sound impatient, I've been waiting for these since February.
DrewHammer is offline   Reply With Quote
Old 06-19-2017, 07:10 PM   #10
If you have no patience waiting...
you could simply drill thru the rear stock slipper plate...
then tap some threads into the rear plate and put in some screws using locktite.
If the slipper assembly can't slip - spin, then it will be locked.
Shouldn't need a different slipper shaft to do that.
Or just wait and spend more money
TacoCrawler is offline   Reply With Quote
Old 06-19-2017, 07:32 PM   #11
Such is life...
BigSki's Avatar
Are the stock Axial parts still available? The original AX-10's didn't use a slipper, we just snapped driveshafts instead.
Natedog likes this.
BigSki is offline   Reply With Quote
Old 06-20-2017, 06:53 AM   #12
Yep, but you gotta buy a transmission case to get the slipper eliminator. I went with the Venom piece because I've warped and stripped the plastic before. Also, I was not aware of LURC piece, otherwise that would be on the truck.
AX80009
kmnss is offline   Reply With Quote
Old 06-20-2017, 12:34 PM   #13
If anyone has an old slash 4x4 slipper it will work in the Axial tranny, and you can tighten it until it is fully locked. Thats what I run in my Wraith with a pro4 and 3s power without any issues for years now. Plus you can find a spur gear anywhere.
BAD RC and Teng like this.
The Violator is offline   Reply With Quote
Slipper Eliminator kit for SCX10/AX10 Transmisson - Similar Threads
SCX10 II - Slipper Eliminator Locked Up New Products and Great Deals 0 10-13-2016 02:49 PM
SCX10 II - Slipper Eliminator Locked Up Locked Up RC 0 10-12-2016 09:24 AM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
