flange bushing source/recommendations I want to replace some worn flange bushings mistly on various scx10 front ends. Any recommendations? need to do 3 rigs and get some spares. I dont mind spending a couple bucks for good hardware, but i drawn the line at 9.99 a front end.8) Considering the lockedup oversized ones, unless someone has a better suggestion. |
Re: flange bushing source/recommendations What size do you need? Check McMaster-Carr |
Re: flange bushing source/recommendations Quote:
Re: flange bushing source/recommendations If you go to jatos link and select ID 3mm, only one option pops up and OD is 6mm. Thats going to be to big. Check with dlux, he sells some for ax10 and wraith, and if it close enough, you can file some down for a no slop fit. I got some ax10 bushings from dlux for my bully 2 knuckles, and filed down OD and top hat length a hair and worked perfect. No slop now. |
flange bushing source/recommendations Hang up and Drive |
Re: flange bushing source/recommendations |
Re: flange bushing source/recommendations http://i106.photobucket.com/albums/m...o/IMG_0224.jpg http://i106.photobucket.com/albums/m...o/IMG_0225.jpg These are Hex heads https://www.tamiyausa.com/items/radi...king-pin-54237 These are Philips crew heads TAMIYA*TA04*KING*PIN*SET... |
Re: flange bushing source/recommendations Oh, so scx10 are the same as a wraith? I didnt know they were the same. Hit up dlux for his wraith no slop bushings. Or those tamiya look good too. |
Re: flange bushing source/recommendations Thanks again everyone. I got some good ideas. Im going to grab some dlux or locked up flanges. But I'm going to order up some plain old 3mm shoulder bolts to try out, also |
