07-29-2017, 04:34 PM | #1 |
Newbie Join Date: Mar 2016 Location: Royal Oak
| Question for "belly draggers"
What's the benefit? I understand there's gotta be more stability, but is it a trade off for loss of break over angle? Been thinking about a new new chassis to replace my "taco'd" Scx10 rails, interested in the belly dragging aspects. Do you guys run shorter shocks as well?
07-29-2017, 06:21 PM | #2 |
| Re: Question for "belly draggers"
Yup. Everything's a tradeoff - you give up breakover but gain stability. I usually have my faster motor setups in my 2 belly draggers as they need a bit more speed to pop up and over. It's a different driving style for sure, but can be very effective when done right.
07-29-2017, 06:42 PM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Ive noticed many real 1:1 low Crawlers regain breakover by going even bigger on tires. You keep the stability while making it less likely to high center because the extra lift now comes from the tires rather than a high floppy suspension Sent from my Nexus 6P using Tapatalk |
08-01-2017, 12:34 AM | #4 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I make up for low belly heights by running enough power to pop the front end up and over sharp transitions. 3s gets the job done nicely
08-01-2017, 06:41 AM | #5 |
It also depends on your style of driving and what you handle better, some people do really well set up low, and some don't. At the very least, try dropping you suspension (giving time to tune), and see how you like it.
08-01-2017, 09:38 AM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
a good set of tires helps too.
08-01-2017, 04:31 PM | #7 | |
| Re: Question for "belly draggers" Quote:
08-01-2017, 07:50 PM | #8 | |
Fixereded. A chassis with an angled skid helps out with break over as does bent rear lower links and a rear pinion rotated up to keep the driveline clear of obstacles. | |
08-01-2017, 09:54 PM | #9 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
You should check out the Toyzuki setups, either first or second gen are amazing for adjustability. Look it up you won't be disappointed.
08-03-2017, 12:23 PM | #10 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
Id say that it ain't fun dragging belly on a 1:1. So I prefer to drive my rc rigs tire on rock instead of by braille. In a 1:1 4wd, more skinny pedal isnt my first instinct when the rock start to tag the rockers/frame/xmember. Also, belly dragging can throw you off your line pretty bad. Belly dragging my rc rigs across the rock isnt for me, but the end of the day, it's all about setting up your rig for the local terrain you wheel on. |
Question for "belly draggers" - Similar Threads | ||||
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
"Pot Belly" C.B.C's class 3 | Mighty1 | 2.2 Scale Rigs | 16 | 08-25-2011 09:41 AM |
HELP, tired of "searching"...."bead-lock" question? | BigMark | Newbie General | 2 | 10-14-2007 10:22 AM |
