G-Transition Shock Help Needed Hi Guys, I need to upgrade my springs in the g-transition shocks on my gmade komodo as the stock springs are way too soft. has anyone upgraded theirs and where did you get them from as i am confused as to what ones will fit them. Any help will be great, thanks :) |
Re: G-Transition Shock Help Needed Quote:
Re: G-Transition Shock Help Needed I wasn't a fan of the Transition shocks either. Everything else that GMade makes is great. What is the length of the springs in those shocks? |
Re: G-Transition Shock Help Needed there are two sets of springs in them both 10mm od, one is 13mm and one is 30mm. |
Re: G-Transition Shock Help Needed im wanting to replace the 30mm spring, to maybe a medium one or perhaps hard. I actually like the shocks and would prefer to keep them on only if i can sort out the spring issue, if not then it will be a case of replacing the shocks completely.http://i.imgur.com/y0rJEgX.jpg |
Re: G-Transition Shock Help Needed i have a set on my 1.9 wraith in sprung set up and i run 2x 2s 5000 batteries and find springs just right...i only put acouple of drops of oil in them to lube the o-rings. |
