10-27-2017, 11:42 AM | #1 |
Quarry Creeper Join Date: Aug 2017 Location: KY
| Traxxas Big Bore mounting tip
I've switched our (me & sons) 3 trucks over to Traxxas Big Bore shocks. I'd searched / read many posts on how to mount the tops of the shocks. I ordered the ProLine Universal Shock Mounting kit, but wasn't really happy with the result. The kit didn't really provide a "ball" mounting range of motion for the upper shock mount. I was in a hardware store recently looking for 1/8 brass pipe nipple to use for XR Steering Mod and seen 1/8" compression fittings They were like $0.25 ea and work perfect sandwiched between 2 M3 flat washers. I use the ball mount in the pics as a stand-off to space the shock out away from the chassis to keep the springs from rubbing the frame. Don't try and order them online, as they kill you on shipping - check your local hardware store (Lowes, HomeDepot, Rual-King, TSC, etc) Last edited by number9; 10-27-2017 at 11:46 AM. |
10-27-2017, 06:41 PM | #2 |
| Re: Traxxas Big Bore mounting tip
That is one solution that will not cost much. If you do a youtube search there are a number of videos on how to mod the Big Bore cap to accept a screw in rod end.
10-27-2017, 07:51 PM | #3 |
Yep, I've seen those and got a bunch of rod ends I could use, but really wanted to try to find another method short of the cap mod. I'm super pleased so far, for $1.00 cost.
Traxxas Big Bore mounting tip - Similar Threads | ||||
Mounting Big Bore Shocks | Dan | Axial RR10 Bomber | 17 | 08-14-2016 09:31 PM |
traxxas big bore??? | bigemike | Axial SCX-10 | 1 | 08-21-2012 09:11 PM |
traxxas big bore mounting options? | madmaxxed | Axial AX-10 Scorpion | 26 | 01-27-2008 04:47 PM |
traxxas big bore? | theonek | Axial AX-10 Scorpion | 7 | 01-15-2008 03:06 PM |
