11-04-2017, 11:11 PM | #1 |
Newbie Join Date: Oct 2017 Location: Canada
| Thinner tires?
Hey, I have an Axail AX10 scorpion and I would like some thinner tires to put on |
11-05-2017, 05:16 AM | #2 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
| Re: Thinner tires?
Thinner tires? Is there any particular reasoning? How are you driving/on what type of terrain do you use this AX10? Sent from my iPhone using Tapatalk |
11-05-2017, 07:21 AM | #3 |
| Re: Thinner tires?
Only reason for narrow tires is mud bogging Hang up and Drive |
11-05-2017, 07:31 AM | #4 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: Thinner tires?
Get a set of Voodoo Pins and Crawler Innovations Double Deuce foams. They're thinner, taller, and a whole bunch sticker than those garbage axial tires. They'll go on your stock deadlocks. You can also order custom narrow pins from Purpmrt on here. Narrowing pins is easy if you want to do it yourself.
11-05-2017, 07:35 AM | #5 |
| Re: Thinner tires?
This is in but the tires wear much faster when there isn't as much tread hitting the ground. I narrowed these a while back, easy sleazy. I watched a video on how to do this seemingly black art and it gave me the confidence to hack apart a few hundred dollars in rubber. It all turned out fine. |
11-05-2017, 07:56 AM | #6 | |
I am doing a Toyota pick up build but also where I live it rains a lot so I cannot go out onto trails in the small puddles in the dirt beacuase it just sinks. Can you recommend some stores that sell thinner tires they don’t have to be taller though, Thanks! Sent from my iPhone using Tapatalk The AX10 is heavier than an SCX10 and where I live it rains a lot so I can’t go in the little puddles on trails because most of the time it starts to sink, can you recommend a store that might sell thinner tires they don’t have to be taller though. Thanks! Sent from my iPhone using Tapatalk Last edited by THX_138; 11-11-2018 at 08:23 AM. Reason: Merged, posts minute apart | |
Thinner tires? - Similar Threads | ||||
making rims thinner | hardcoreghost | Tires and Wheels | 2 | 03-08-2012 04:20 AM |
Lacquer thinner to soften tires? | strap624 | Tires and Wheels | 10 | 11-05-2011 11:46 AM |
Testors acrylic thinner ? | BigSki | Paint and Body | 1 | 04-02-2011 05:33 PM |
Airbrush-Thinner to paint ratio | aftershock1 | Paint and Body | 1 | 07-13-2009 11:40 PM |
