Thread: Why RC rock clawers have suspension?
Old 02-04-2018, 03:36 PM   #1
Default Why RC rock clawers have suspension?
First I want to say that I am talking of competition Class 1 - Superclass and Class 2.2 rigs not other ones.
The suspension on an RC car has the the only functions of keeping the wheels on the ground in order to make it the most drivable possible and put as much traction to the ground as possible.
I am use to design suspensions and other staff for real vehicles and now I am designing an RC superclass rock crawler. And I have realized that it is a completely different scenario and most of the standards on a vehicle suspension do not apply to RC rock crawlers or apply differently.
The issue is that in order to make the suspension work as better as posible the unsprung mass should be as low as posible. But in the case of this crawlers most of the mass (provably around 90%) is unsprung mass. So now great part of the suspension function has to be taken care by the tires and foam and links.
So the question is, what is the function now of the shock absorbers, as they barely have to support any weight?
I believe they are energy reservoirs systems that are able to save some energy when dining and release afterwards when marching again. The do not act like that when scrubbing because we normally use one way only shock absorbers (may be someone have already have tried double direction shock absorbers)
So I think that we may start thinking and tunning them differently.
Please let me know your thoughts.
gonper is offline   Reply With Quote
Old 02-04-2018, 03:47 PM   #2
MODERATOR™
EeePee's Avatar
Default Re: Why RC rock clawers have suspension?
Controlled weight transfer.
EeePee is offline   Reply With Quote
Old 02-04-2018, 04:02 PM   #3
Yes good point, that is a function that the shock absorbers have to handle.
Old 02-04-2018, 05:33 PM   #4
Are you familiar with torsion chassis' on rc crawlers? I have a Dahu torsion chassis that I'll be building an MOA crawler around (hopefully soon) that eliminates all traditional shocks/springs/links and relies on the chassis itself to provide the controlled movement of the axles. Billet Works also sells a 1/2 torsion chassis, called the Mantis, where the front end is still sprung. These types of chassis' aren't for everybody and they are sure to drive/react differently than traditional suspension setups, but they might get you thinking further outside of the box if that's what you're after?
TheLetterJ is offline   Reply With Quote
Old 02-05-2018, 06:42 AM   #5
You are right, those are very good examples. The suspension is provided by the tires/foams and the chassis takes care of flexing and control.
The chassis flexibility is where energy is stored when dining and scrubbing.
About reactions, I think that if oil dampeners are added to the Dahu chassis in order to control its flex reactions will make it easier to drive.
And yes I am thinking out of the box for my superclass design (here: Crazy axles idea design)
Anyway I think that for a superclass a flex chasis may not bee a good idea due its size, and because it may be difficult to fine tune it.
Old 02-05-2018, 10:05 AM   #6
OP have you seen the BWD Mantis chassis? BWD XR-Mantis Prototype Chassis Kit...All New!
Sneetches is offline   Reply With Quote
Old 02-05-2018, 11:00 AM   #7
Articulation to keep wheels in contact with surface, therefore creating traction.
mewalsh100 is offline   Reply With Quote
Old 02-06-2018, 01:41 PM   #8
Thumbs up Re: Why RC rock clawers have suspension?
That's actually the best argument for Shocks and Springs - particularly Springs....
To keep Pressure on the surface, with the tires.
You could almost run the Shocks empty..... as Damping at Crawler speed is nearly redundant. The Springs are doing all the work.
PoorManRC is offline   Reply With Quote
Old 02-06-2018, 07:08 PM   #9
MODERATOR™
EeePee's Avatar
A torsion chassis is a spring and the biggest problem with them is their lack of dampening, which is why you don't see many anymore.
Old 02-07-2018, 06:13 AM   #10
Sorry to disagree, but in this type of crawlers due its low speed the springs does not play much effect on keeping the wheels on the ground, only gravity force is the one that keeps them on the ground.
Although the springs regulate how the gravity force is distributed among the wheels, because they regulate how torsion happens and derivate some of the gravity force from one/s wheel/s to another/s.
The oil dampeners makes that the movements created by the force transitions to be slower. That avoids fast movements of the axels/wheels that may create big inertial forces that can affect the vehicle stability, so oil dampeners makes the rig more controlable.
So yes oil is necessary in order to have a more stable and easy to drive vehicle.
Old 02-07-2018, 06:29 AM   #11
Yes, you are right, I think that if oil dampeners are added in order to avoid high speed chassis movements they could be great chassis due their lightness, ground clearance and toughness, at least for 2.2 class.
For superclass I thing that they may be too flexible and the axels with the double steering may be wandering around instead of following the desired paths.
Old 02-07-2018, 06:34 AM   #12
You don't see them much anymore, but I recently saw a guy driving one and he was doing amazingly well with it. I think some of it comes down to driving style. But, for my "style", I'll take shocks/dampeners all day long!
Old 02-07-2018, 07:52 AM   #13
Moderator
JatoTheRipper's Avatar
Rock Clawler?
Am I the only one that thought of this toy truck from my childhood?
Old 02-07-2018, 11:16 AM   #14
Originally Posted by JatoTheRipper View Post
Rock Clawler?
This is awesome...
We need these wheels on real RC trucks.
Like paddle tires that would extend or retract based on terrain!
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 02-07-2018, 03:56 PM   #15
MODERATOR™
EeePee's Avatar
Pimp Cane, which I never had
TCS Stick, which I had, and has one shock on each axle, on the same side
DNA SSS, here EP's 'Sportsman' SSS Axial
Old 02-08-2018, 05:03 AM   #16
I like the simplicity of Pimp Cane or TCS Stick but as they can not flex on their length, dig/scrub functions does not work as they should because they only have the flexibility of the tires to store energy.
That is very cool design, using links to keep the axels on position and a flex chassis parts to reduce the weight of the shock absorbers and make it more simple.
I suppose that it is difficult to tune it.
Old 02-08-2018, 07:41 AM   #17
Nope..
Brainstain's Avatar
Wasn't there an emoji that was talking to a wall at one point? I feel like it is now the only appropriate response.
Brainstain is offline   Reply With Quote
Old 02-08-2018, 08:14 AM   #18
~THE SCALE SHOP~
the other down side to the torsion rigs is they require alot of wheel weight to work well. opposite of where the sport has gone.
i had a super and later a 2.2 pimp cane.
STANG KILLA SS is offline   Reply With Quote
Old 02-26-2018, 12:42 PM   #19
Some crawlers can spit out some pretty good speed. My brushless AX10 can hop a pretty good gap. Without shocks it would bounce like crazy.
I typed this almost auto correctly free
xCoolHandLukex is offline   Reply With Quote
Why RC rock clawers have suspension? - Similar Threads
rustler suspension arms versus bandit suspension arms... STEEL_CITY_CRAWLER Non Crawler RC's 5 08-30-2010 11:05 AM
