03-13-2018, 10:09 PM | #1 |
Quarry Creeper Join Date: Feb 2017 Location: Adirondack Park
| Spektrum 3rd Channel?
Does anyone know if Spektrum radios have a 3rd channel with a 3 position switch for winch use? Not looking for a big dollar radio to get this feature as the RC4WD radio that they use for their RTR's has it.
03-14-2018, 12:52 AM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Spektrum 3rd Channel?
Depends on the Spektrum. The older radios do. There's also the option of a 2 position winch controller from HeyOk. Another option is a hacked GT3B. It's one of the least expensive radios out there and when easily hacked gives you 3ch,6ch,or 8ch with the appropriate inexpensive receivers, the ability to map almost any button to any channel as a 2 position,3 position, momentary long press and short press, and step rate. It also has more adjustments than more expensive radios. Sent from my SM-N900T using Tapatalk |
03-14-2018, 02:16 AM | #3 |
Rock Stacker Join Date: Feb 2018 Location: US
I'm on a DX-6i and if I was gonna wire a winch to it tonight I'd probably do away with the usual winch controller and put a small...say, 1/18th or 1/24th scale...brushed car ESC on the throttle stick for the winch, then put a power cut on the 'gear' channel.
03-14-2018, 07:07 AM | #4 |
Quarry Creeper Join Date: Aug 2017 Location: Satan's Armpit
| Re: Spektrum 3rd Channel? Yes, they do. I have a (discontinued) DX4C with 2 AUX channels that I can program to have either a 2 position or 3 position switch. I used one with a RC4WD wired winch controller, and the other for lights with a HeyOK 3 position light controller.
03-14-2018, 10:03 AM | #5 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
DX4C here....lights, dig, winch no problem.
03-14-2018, 10:17 AM | #6 |
Thanks, will look around for a DX4C.
03-15-2018, 07:27 AM | #7 |
| Re: Spektrum 3rd Channel? I'd try to get either a DX4C, or the newer DX5C if you can't find a DX4C, with the SR415 receiver. That receiver has 4 Ch total (Steering, Throttle, 2 AUX) without the AVC, which is difficult to turn off it seems, and not that great of a feature to have on when trying to crawl.
Spektrum 3rd Channel? - Similar Threads | ||||
Spektrum DX3c 3rd channel issues | Jus | Electronics | 2 | 03-25-2013 10:13 AM |
Spektrum DX3S 3rd Channel Mod? | cmyers1 | Electronics | 10 | 02-26-2011 06:25 PM |
Spektrum DX3.0 3rd channel? | redswr | Electronics | 2 | 11-03-2009 03:03 AM |
spektrum dx3 3rd channel | dieselfuel | Electronics | 51 | 02-21-2007 12:41 PM |
Spektrum 3rd channel. | robbo989 | Electronics | 5 | 10-17-2006 07:30 AM |
