Thread: Xtra Speed Portal Axle Gear Ratio?
Old 03-18-2018, 06:58 PM   #1
Default Xtra Speed Portal Axle Gear Ratio?
Hey guys,
I am checking out these portal axles for a build and trying to figure out what the gear reduction ratio in the portals is, or if they are 1:1?
Thanks, Lance
https://www.amainhobbies.com/xtra-sp...hoCG4kQAvD_BwE
Lance Carbuncle is offline   Reply With Quote
Old 03-18-2018, 09:53 PM   #2
Default Re: Xtra Speed Portal Axle Gear Ratio?
These are the portal gears for them so I think they're 1:1
https://www.ebay.com/itm/Xtra-Speed-...1/382316067429
yjdavid is offline   Reply With Quote
Xtra Speed Portal Axle Gear Ratio? - Similar Threads
Xtra Speed Metal Axle Housing Review Myndefuk Axial Wraith 9 01-04-2018 05:49 AM
Xtra Speed axle Shawns303 Axial SCX10 II 148 12-26-2017 07:22 AM
Xtra speed steel axle housings? Spence Axial AX10 2nd-gen 2 05-10-2017 05:06 PM
Xtra speed axle shafts on wraith? dannyboyjdc Newbie General 1 11-21-2016 07:09 AM
Xtra speed aluminium axle Johan_Eriksson Axial SCX-10 0 11-12-2016 01:37 PM
