12-02-2018, 02:53 PM | #1 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Aluminium skid plate or not
This is about my SCX10, but I guess it's relevant to all like rigs. I'm considering to change the plastic skid plate with an aluminium one. Simple question, is it a good idea? Heavier, stronger OK - but does it slide over rocks, or will I get stuck more often? Sent from my SM-G930F using Tapatalk |
12-02-2018, 03:07 PM | #2 |
| Re: Aluminium skid plate or not
It won’t be considerably heavier, but it will not slide over rocks nearly as well as the plastic.
12-02-2018, 03:13 PM | #3 |
| Re: Aluminium skid plate or not |
12-02-2018, 04:25 PM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
Depends on what your goals are. It will no doubt be stronger but it will not slide on rock as good as plastic. I'm not sure I have ever heard of anyone complaining about how weak the stock skid is, mostly only about getting hung up on it. The decision is yours.
12-02-2018, 11:50 PM | #5 |
The stock skid is just fine, and a aluminum skid is a waste of money imo...
12-03-2018, 12:12 AM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
If it were a decent grade of aluminium that is actually fairly hard & was anodised (adds surface hardness) & was machined so it was smooth underneath it Might be worth doing. But most are the softest, cheapest, easiest machining cheesium they can find & to bling them up they pocket mill all sorts of nice catch points out of the underside. Things like this for any extra strength or mass they have will just hang up so much as to be more irritating than benefit Something in smooth easy sliding Delrin would be much nicer (assuming you can find anything in stock anywhere that is) https://www.amainhobbies.com/vader-p...rscx10/p698753 https://thescaleshop.webs.com/chassis.htm Last edited by altd896; 12-03-2018 at 08:11 PM. |
12-03-2018, 04:47 AM | #7 |
Yes, I would say it is not an upgrade. I would put that money towards something that enhances performance. Say, some good tire foams if you have not done that yet.
12-03-2018, 02:34 PM | #8 |
Newbie Join Date: Jul 2010 Location: Idaho
You could consider using a trans skid that has a higher flush profile even with the chassis rails. One made out of Delrin which would offer less friction then plastic or alum. Sent from my iPhone using Tapatalk |
12-03-2018, 06:52 PM | #9 |
People make all kids of claims about the sliding ability of plastic vs aluminum and I've never found a noticeable difference. The most important thing is that it's smooth on the bottom and doesn't have any spots to hangup like on that Integy skid above. Avoid that thing - too many snagging spots.
12-04-2018, 05:00 AM | #10 | |
| Re: Aluminium skid plate or not Quote:
12-04-2018, 06:32 AM | #11 | |
12-04-2018, 06:52 AM | #12 | |
Sent from my SM-G930F using Tapatalk | |
12-04-2018, 07:01 AM | #13 |
Thanks for all the input, guys! I see all your points. I already got a delrin one mentioned above and look forward to try it. I have some aluminium axles on a rig and noticed that they will both slide over rocks, and also suddenly hang up completely on certain rocks (an upside to that is they look very cool when they are worn over time ) One of the reasons I considered an aluminium skid plate is that my old Axial one looks horrible and I don't know if it will suddenly crack in half one day, and maybe aluminium would also provide a more stable base for the transmission case. Sent from my SM-G930F using Tapatalk |
12-05-2018, 05:20 AM | #14 | |
Having said all that, I'm not a Comp guy, but there's a reason 90+ percent of them run plastic, and it's not because they enjoy constantly tightening things and dealing with stripped out holes. It slides over rocks better and is typically a good bit lighter than the aluminum equivalent. Last edited by mewalsh100; 12-05-2018 at 05:23 AM. | |
Aluminium skid plate or not - Similar Threads | ||||
Measurements for stock AX10 Transmission mounting plate/skid plate | Apoch | Axial AX-10 Scorpion | 5 | 04-09-2012 07:53 AM |
Steel or aluminium axil skid plate | Skier | Venom Creeper | 9 | 06-07-2011 01:07 PM |
Aluminium skid plate | Tom94offroaduk | General Crawlers | 2 | 01-20-2011 11:48 AM |
Skid plate | minor_threat | Axial AX-10 Scorpion | 5 | 03-06-2009 07:16 PM |
