01-15-2019, 06:48 AM | #1 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Internal servo winch spool
I'm looking to build a internal spool servo winch. I'm having issues locating a spool for it. The builds I have seen use a 3racing winch spool and bearing. Does anyone know where I can buy just a spool and bearing? Or do I have to buy a whole scale winch and tear it apart? Anyone know of other spools that might work for this application? Thanks for the help and knowledge! Have a great day!
01-15-2019, 07:55 AM | #2 |
| Re: Internal servo winch spool
I dont think it matters just use a shaft and some washers the only porpise of the spool is to keep the line in place with a internal spool the line is kept in place by the case the washers will keep the line from binding inside the case
01-15-2019, 12:51 PM | #3 |
I didn't even think of that. That's a good idea. Thank you. Could always solder some aluminum washers to a aluminum tube and make my own. I kinda like the one side riding in a bearing. I'll figure something out.
01-15-2019, 01:41 PM | #4 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
Check out HeyOK or Powershift, they both make servo winches and you might get some ideas. |
01-17-2019, 07:42 PM | #5 |
You can create a bearing pocket with epoxy just make sure you coat the bearing with grease first And be sure to post up what you end up with |
01-17-2019, 08:04 PM | #6 |
Great ideas in here, I also came up with this in a search, they used a sewing spool and one used some (round) servo horns that often come with servos and dont get used. Scaler Tech: How to make a servo winch spool... |
01-18-2019, 05:03 AM | #7 |
Thanks for the pointers guys! It might be a bit before I dig into this project, but when I do I will surely post it up on here.
01-18-2019, 06:49 AM | #8 |
Rock Stacker Join Date: Jul 2018 Location: MN
| Re: Internal servo winch spool |
06-23-2020, 11:07 AM | #9 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
What did you end up using? how did it work out for you? Lou |
Internal servo winch spool - Similar Threads | ||||
Servo winch spool | greenjk | Electronics | 19 | 09-07-2019 04:17 PM |
Servo Winch Spool | MiniMorris | Electronics | 0 | 01-05-2013 12:43 PM |
