Thread: JJRC willys jeep 2 speed driveshaft question?
Old 03-04-2019, 03:52 PM   #1
Default JJRC willys jeep 2 speed driveshaft question?
Will the WPL 2 speed transmission fit using the existing driveshafts?
Here is the you tube video with the 2 speed(fast forward towards the end)
https://www.youtube.com/watch?v=SKPg318tYnQ
https://www.ebay.com/itm/2-Speed-Gea...MggC:rk:1:pf:0
willygee is offline   Reply With Quote
Old 03-04-2019, 04:04 PM   #2
kincer's Avatar
Default Re: JJRC willys jeep 2 speed deiveshaft question?
Your best bet is to use the CV style metal driveshafts for the WPL trucks, I have six of these little trucks and those are the best shafts around for all of these trucks, I'm running them on all of mine.
kincer is offline   Reply With Quote
Old 03-04-2019, 04:13 PM   #3
Thanks for the advice.. i was hoping the 2 speed would fit the existing driveshafts .Dimensions hard to come by.I will upgrade to better shafts once i no what i need . The 1/10 JJRC Q65 jeep and 2 speed on its way from china..should be fun.
Old 03-04-2019, 04:20 PM   #4
kincer's Avatar
I have no idea if the stock shafts will work but I do know this, the 2 spd has flats on the output shafts for set screw style shafts so you would probably have to try to super glue them on, also the 370 motor has way more torque and power than the stock 130 motor so if they do work they are not going to last one run, or not not much more than that.
Old 03-04-2019, 04:35 PM   #5
Can you tell from the video if the shafts are original ? They are black and don't look like typical shiny steel upgrades.
Old 03-04-2019, 04:55 PM   #6
kincer's Avatar
I can't tell, they are possibly plastic style with set screws, hard to tell. The stockers are press fit on splined output shafts.
JJRC willys jeep 2 speed driveshaft question? - Similar Threads
JJRC JEEP Willys rcradio General Crawlers 26 08-30-2019 12:47 PM
JJRC Army Jeep kincer Micro Scale Rigs 16 05-07-2019 05:04 AM
Question about 1/6 Willys Jeep Synister_Intent Large Scale Rigs 4 06-30-2016 09:29 PM
