Skyrc toro brushless Anybody use the skyrc toro brushless motors? I found this 2200kv n was wondering how good they are. Ive got a goolrc BL motor, but cant fimd a low kv in the size i need. Just so happens this one is the right size n its 4s capable (or so it says lol). Im lookin for a low kv, 540 or 550 size, but no longer than 60mm max. Im using the ax10/scx10 3 gear trans n ar60 axles. Any input is much appreciated.https://uploads.tapatalk-cdn.com/201...43b8e846d9.jpghttps://uploads.tapatalk-cdn.com/201...b3bcd20efb.jpg Sent from my SM-J327VPP using Tapatalk |
Re: Skyrc toro brushless Is it for a crawler? What kind of esc do you have? Sent from my SM-G960W using Tapatalk |
Re: Skyrc toro brushless Never heard them. It is going to cog (twitch) at low speed because it is sensorless. If this rig is just for speed it may be alright. why are you looking for such a low kv? The holmes puller pro and puller pro stubby are sensored so no coging and are under 60mm long. Also all of the holmes revolvers are under 60mm long, outrunners are special and don't need sensors,except they are loud. |
Re: Skyrc toro brushless Its not for a crawler, im buildin a solid axle monster truck. I want a lil speed out of it. Never thought to mention wat esc, its a traxxas mxl-6s. Ive got a build thread in the monster truck section Sent from my SM-J327VPP using Tapatalk |
Re: Skyrc toro brushless I'd go for the 1800kv HH Revolver, smoothest motor for the money (and loads of torque) if you don't mind a little more noise than usual, and you can run it on 4s Sent from my SM-G960W using Tapatalk |
Re: Skyrc toro brushless Quote:
Re: Skyrc toro brushless I've had great luck with these blue no name ones from eBay. Also 4s rated (though I don't have 4s to try). They stay cool on 3s.https://uploads.tapatalk-cdn.com/201...6a5b2ab547.jpg Sent from my SAMSUNG-SM-G920A using Tapatalk |
