Thread: SCX10 Builders Kit Metal Transmission?
Old 03-21-2019, 04:20 AM   #1
Default SCX10 Builders Kit Metal Transmission?
Anyone have a recommendation for a metal transmission case/ motor mount for the Axial SCX10 Builders Kit? I had planned on a Vanquish case but it doesn't seem they produce one for this kt, I did ask them via email but never received a response.
sherbs is offline   Reply With Quote
Old 03-21-2019, 05:34 AM   #2
Default Re: SCX10 Builders Kit Metal Transmission?
As far as I know there is no direct replacement. You can find plenty of metal cases, but will need to get a motor plate and spacers.
Sent from my Moto G (4) using Tapatalk
rcdriftmasterj is offline   Reply With Quote
Old 03-21-2019, 06:21 AM   #3
The old Scx10 case will bolt directly to the Scx10II RBK skid. so after adding the motor plate and spacers you should have o problems.
lonleycreeper is offline   Reply With Quote
Old 03-21-2019, 10:51 AM   #4
Thanks All, now to the search!
SCX10 Builders Kit Metal Transmission? - Similar Threads
raw builders kit transmission question redbull8983 Axial SCX10 II 18 11-10-2019 07:28 AM
SCX10 II raw builders kit-questions Spence Axial SCX10 II 2 11-11-2018 07:34 AM
